Author Topic: 130PD injectors into 115PD  (Read 6100 times)
Offline sveed1.8T
« on: 09 July 2012, 21:36 »
Now if I was to do the above, would it be worth it in terms of gains? Or would I then need the turbo to go with it to really notice the difference? :undecided:
I know there isn't a "huge" amount of difference between the two engines, n I'm trying to work out what tweaks I can do before looking at getting a map! I don't like the idea of just mapping a 115PD and still not hitting 150bhp!! :lipsrsealed: Especially after having a Spec1 mapped 1.8T! :undecided:
I'm already running a full milltek system with decat, smoothed airbox, Pipercross panel filter and a cold air feed in case you were wondering.
Offline sveed1.8T
Re: 130PD injectors into 115PD
« Reply #1 on: 12 July 2012, 22:31 »
Surely someone must know? :huh:
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #2 on: 13 July 2012, 09:47 »
I really don't know  :cry:
You'd have to ask one of the bigger boys. I'd imagine it help with fuel economy and perhaps a slight amount of power, but you still have the same amount of air going in and more fuel...So yeaaa  :undecided:
Offline sveed1.8T
« Reply #3 on: 13 July 2012, 12:34 »
The problem is that the 'bigger boys' are not speaking up! :undecided:
It would make sense, but I'd just like to know if anyone has any insight into updating their injectors on a diesel! :sad: :angry:
Offline scarr89
« Reply #4 on: 13 July 2012, 18:38 »
As far as I know you only need to uprate injectors if you get a bigger turbo.
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 13 July 2012, 18:49 »
you'd probably gain more smoke than power, isn't really worth it unless you're putting the asz or arl turbo on
Offline scarr89
« Reply #6 on: 13 July 2012, 18:59 »
Thanks 'bigger boy'  :laugh:
Offline sveed1.8T
« Reply #7 on: 13 July 2012, 20:18 »
Love it! :grin:
Topher, if I was to change the injectors for 130PD injectors and upgraded to a 130PD turbo, would I then need to change the cams, or would it be fine without? :huh:
Sorry for all the questions, just trying to work out if it is financially worth it!?
Offline scarr89
« Reply #8 on: 13 July 2012, 21:03 »
Love it! :grin:
I think all cams are the same  :undecided:
Offline brayson
« Reply #9 on: 07 September 2012, 16:06 »
I was looking into doin gthis on my 100 but i cant be arsed at the minute, as far as i am aware to make the most effective use you need the 130 intake pipe with maf etc, turbo, injectors, and some people talk of a 3 bar map sensor.
Im sure also you can have the original ecu reflashed i think its called which saves you the hassle of looking for a 130 ecu.
Like i say im sure thats all that needs to be done, the cam and stuff can still be used, like i say if im wrong someone with more experience please point it out as i am still in learning stages of the PD engine :)
