Golf mk3
hardmonkeys
How to remove trim around seatbelt adjuster
Topic: How to remove trim around seatbelt adjuster (Read 2237 times)
Khare
Serious forum addict
The bear that khares
09 July 2012, 20:48 »
As title. How the hell do you separate the trim from the seatbelt? Only way I see is by cutting it
F17BAD
Forum addict
Golf MTM S3 GTI TURBO
Re: How to remove trim around seatbelt adjuster
09 July 2012, 20:49 »
un bolt the seatbelt mate is the way
Not no ordinary GTI....
www.mixcloud.com/kells/
Gti_Jamo
1991 Corrado 1.8 G60
09 July 2012, 20:54 »
Aye 17mm bolt at the bottom needs to come out.
97' Mk3 Golf Gti 2.0 8v Rebuild Project
http://www.golfgtiforum.co.uk/index.php?topic=208865.0
Khare
09 July 2012, 20:56 »
But the bottom of the seatbelt is on a slide, the fabric loops back on itself. Do you mean unbolt the side?
Is it the same for the rear trim panels?
Gti_Jamo
09 July 2012, 20:59 »
The bolts that need to come out are down near the floor, then you pull the whole thing through the trim your removing.
tweed
Forum addict
Remove the seal cover. This will show the 17mm you can undo to slide the hooped end of seat belt over the metal bar.
Did mine last week
Untitled
by
tweedub
, on Flickr
Khare
Reply #6 on:
09 July 2012, 21:15 »
Nice one guys cheers. Is it the same for the rear seatbelts yeah?
tweed
Forum addict
Reply #7 on:
09 July 2012, 21:50 »
Quote from: Khare on 09 July 2012, 21:15
have to loosen off the rear card, lift it up and you will be able to undo the seatbelt.
Untitled
by
tweedub
, on Flickr
Khare
Reply #8 on:
09 July 2012, 21:57 »
Awesome. Cheers buddy.
tweed
Forum addict
Reply #9 on:
09 July 2012, 22:17 »
no problems. Quite easy once you start dude
Untitled
by
tweedub
, on Flickr
Golf mk3
hardmonkeys
