Author Topic: 2010 VW Golf Glow Plug - Light - pls help  (Read 2911 times)
Offline javsta
« on: 09 July 2012, 18:14 »
Hey Guys,
I recently seen that the glow plug light has come on the dashboard - with a display saying "engine fault - Workshop" (something along these lines)
The engine seems a little ratlly/juddery - no loss of power or anything in fact strangely it feels more responsive.
Comes on periodically - can anyone shed some light on this please?
is there anyway of resetting the memory??? like on fords turn the key five times to the ignition position, 2 beeps later its reset
Thanks in advance
Offline The Doc
  • E63s Estate - Vito Sport
Re: 2010 VW Golf Glow Plug - Light - pls help
« Reply #1 on: 09 July 2012, 18:23 »
You need to get a diagnostic done on her.
Where are you based?
Offline javsta
« Reply #2 on: 09 July 2012, 18:29 »
Hey Doc,
Based in the midlands - Derby
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 09 July 2012, 18:44 »
check your brake lights are working. a faulty brake pedal switch can illuminate the glow plug symbol.
Offline javsta
« Reply #4 on: 09 July 2012, 18:45 »
Doc is there is easy way to find out what the fault code is by turning the key or anything alike??
Offline javsta
« Reply #5 on: 09 July 2012, 18:49 »
Cheers Topher,
Just checked all brake lights working ok.
just happened to switch it on too and no errors on MFD or glow plug light - any ideas what this might be?
urgent regen possibly it is a oil burner
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 09 July 2012, 19:22 »
it could be dpf related, although the plug light tends to flash constantly in those cases. if you want to take a trip down the A38 i can take a quick look for you, might turn out to be a sensor which would be a straight forward warranty job.
i think there is a way to access fault codes using the climatronic but i can only find info on the older versions.
Offline The Doc
« Reply #7 on: 09 July 2012, 21:36 »
As above chaps - thanks TOPHER  :wink:
Offline javsta
« Reply #8 on: 09 July 2012, 22:18 »
Thanks Topher I think you might be right quite well possibly be DPF related - will see what happens when i take it for a blast on the motorway tomorrow.
I dont think I have climatronic (assuming its the electronically controlled cabin temp)
I thought I had recognised midland VW logo somewhere just realised my last service was done there.....have to say it was a good job....found a fault the stealer could not find.
Do let me know if there is a way I can find out the fault without the OBD port :) thank you
