Author Topic: electric windows not working  (Read 993 times)
Offline less smoke more poke
« on: 09 July 2012, 13:12 »
Bit of a problem with the Windows on the golf they won't go up or down on either of the switches , they only way is to either lock the car and hold it to shut , or open the car and hold it to open. I thought this was a relay myself but could be wrong was also told the reverse light fuse has something to do with it  :undecided: . anyone any ideas or answers even better?  Also electric mirrors don't work would this be part of the same problem?
the sunroof works on the switch, when I go to open or close it will only lift one side up or down, has a cable or bar broke to cause this? I don't want to take it off because of our lovely Irish weather   :grin:
If anyone could help me with this it would be much appreciated
Offline Deano2711
  • 1992 VR6
Re: electric windows not working
« Reply #1 on: 09 July 2012, 14:03 »
For the windows and mirrors check the wiring inside the rubber grommet that runs from the pillar to the door as these tend to snap pretty easily.
« Reply #2 on: 09 July 2012, 14:08 »
had a look nothing broke at all its strange since both sides dont work on the switch but when you lock / open it with the key it works
« Last Edit: 09 July 2012, 14:20 by less smoke more poke »
