Author Topic: Xenon adjusting  (Read 2073 times)
Offline Ozram
Xenon adjusting
« on: 09 July 2012, 12:04 »
Sorry if this topic has been covered before. The search failed to find anything.
I'm thinking of retrofitting Xenons and I know all about the legalities with washer jets and suspension levelling. I'm looking at some from Germany but want to know if LHD can be adjusted to RHD? I'd heard that some Xenons have a switch to set them to a straight ahead setting if you went from say UK to Germany. Can the lights then be further manually adjusted to suit UK / Australian driving? That is change them from LHD to RHD?
Anyone got a pic or schematic of the switch?
Thanks
« Last Edit: 09 July 2012, 12:37 by Ozram »
GTI MY12.5 CSG DSG | DETROIT RIMS | LED TAILS | LAKIN PLATE HOLDER | OPTI-COAT | TINT | RNS510 | LED interior | VWRACING CAI l BLUEFIN |
Wish list - | Milltek / SPM exhaust | RVC | P3 Gauge
Offline ScottA
Re: Xenon adjusting
« Reply #1 on: 09 July 2012, 12:19 »
On my DIS, I have "Travel Mode" (or something similar) which changes the alignment for driving in LHD countries. I assume this can be done with VCDS too. Not sure how it would all work without the suspension leveling though. I believe I noticed a way to adjust them manually last time I looked but I can't confirm this 100% at the mo. I'm sure someone else will be along with more info soon
Offline dubber36
Re: Xenon adjusting
« Reply #2 on: 09 July 2012, 12:43 »
I'm not sure about the L-RHD thing, as my 2004 Passat with bi-xenons had a lever on the side to alter the beams for driving abroad. It only flattens the beam tho', not convert it to true LHD. I don't know if the newer cars have lenses that will alter the beam pattern to L or RHD. I suspect that "Travel Mode" is no different to my old Passat, albeit altered using wires and motors.
Offline The Doc
  • E63s Estate - Vito Sport
Re: Xenon adjusting
« Reply #3 on: 09 July 2012, 13:13 »
Offline mike.
Re: Xenon adjusting
« Reply #4 on: 09 July 2012, 19:51 »
Piece of cake... :shocked: :shocked: :shocked:
Never again   :evil: :evil:
Travel mode does the same as the levers, just flattens the beam to stop it blinding oncoming traffic so LHD lights can't be used on a RHD car.
The AFS controller controls the Travel Mode function and it needs a self leveler and power modules in the lights to work..
« Last Edit: 09 July 2012, 19:54 by mike. »
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Ozram
Re: Xenon adjusting
« Reply #5 on: 09 July 2012, 21:28 »
Thanks for the replies guys.
Seems like a doddle of a job then?  :laugh:
I'm a one RVC camera install veteran, I can handle anything :wink:
