Author Topic: problem after fitting k03s  (Read 2976 times)
Offline Dalo Harkin
Re: problem after fitting k03s
« Reply #10 on: 10 July 2012, 12:37 »
i know i said burning oil and it probabaly wasnt the best choice of words
theres no smoke just oil and coolant levels keep going down and there isnt any leaks at all anywhere part from a very small drip from the sump plug but its minimal
You would normally need to top up the coolant as it goes through the system anyway, but as for oil 4.5 litres from memory to fill, so how much did you use?
Offline GTIcheeseman
« Reply #11 on: 10 July 2012, 13:14 »
4.5l
Offline rio_gti
« Reply #12 on: 10 July 2012, 14:40 »
when i changed the sump i had a 5l bottle, and it all went in and didnt meet the top of the dip stick so just top it up and keep an eye on it, is it still goin dowm as we speak then?
Offline JimBR
« Reply #13 on: 10 July 2012, 16:27 »
Is there oil and coolant under your car when its parked up?
If there isnt id say the new turbos bad. Coolant may appear to be dropping as it hasnt been bled properly and there is air in the system maybe?
« Last Edit: 10 July 2012, 16:40 by JimBR »
Offline Dalo Harkin
« Reply #14 on: 10 July 2012, 19:45 »
You left the sump bolt out didnt you  :grin:
« Reply #15 on: 10 July 2012, 20:08 »
no the bolts in lol
theres only a a drip coming from the sump plug but its not bad atm it seems to have stopped going down now ill check tomorrow as im going out most of the day
Offline Dalo Harkin
« Reply #16 on: 10 July 2012, 20:46 »
no the bolts in lol
Was aimed at rio_gti mate  :wink:
Offline rio_gti
« Reply #17 on: 10 July 2012, 23:37 »
no the bolts in lol
Haaaaa you'll only do it once  :wink:
