Author Topic: Noisy engine (almost like diesel) Tractor (solved)  (Read 2717 times)
Offline pickles
  • Next!!!
engines starting to sound like a tractor. sure its mostly when cold.
To shed some light on the matter, my exhaust hasnt been fixed to the centre bracket for some time  :lipsrsealed:.  Im thinking the vibrations and knocking about etc i may have upset the turbo in someway.
turbo to exhaust joint/gasket seems fine.
exhaust doesnt apear to be leaking either so im thinking its the manifold between turbo and the engine.
Can any1 tell me what this part is called, seen load off manifolds but with T25 flanges, these are for Garret turbos r they not
« Last Edit: 21 July 2012, 11:00 by pickles »
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Toby
  • Car - less
Re: Noisy engine (almost like diesel) Tractor
« Reply #1 on: 08 July 2012, 22:08 »
Missfireing?
Any codes??
Ignition amp  :smiley:
Currently down under
Offline pickles
  • Next!!!
« Reply #2 on: 08 July 2012, 22:33 »
nothing like that at all m8, no codes, i reckon with the vibrations n stuff with it not being fixed properly has maybe f**ked a gasket or somethin
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
Mapped
Nearly S3 time  :)
Offline harlemex
« Reply #4 on: 08 July 2012, 23:04 »
Thats a manifold, tghought you already knew that  :huh:
Offline pickles
  • Next!!!
« Reply #5 on: 08 July 2012, 23:22 »
yeah just checkin lol, got mixed up with inlet n outlet for a minute lol
Mapped
Nearly S3 time  :)
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #6 on: 09 July 2012, 00:15 »
When was the last service inc. oil change?
Offline pickles
  • Next!!!
« Reply #7 on: 09 July 2012, 00:24 »
changed the fuel filter the other week, oil n  spark plugs wr changed bout 4/5 month ago altho im not sure they wr the correctly gapped plugs  :embarassed:
Mapped
Nearly S3 time  :)
Offline JimBR
« Reply #8 on: 09 July 2012, 13:14 »
Secondary air pump?
Maybe not if its an AGU..  :grin:
Offline pickles
  • Next!!!
« Reply #9 on: 09 July 2012, 20:27 »
was the joint between turbo and downpipe, forgot i had a bolt  that i just could not tighten due to not having a universal joint, had another bash at it but failed lol, smothered it with exhaust paste for now, seems to be holding . touch wood, really need to get it tightened up  :lipsrsealed:
Mapped
Nearly S3 time  :)
