Wonder if anyone has encountered this?
I'm in the process of swapping the springs on my 1999T golf estate (Mk3). Fitted fronts and found that due to the shorter springs, there is a gap between the spring cap as it lays on the top of the spring and the bearing of about 10mm, meaning that when jacked up the spring is actually loose and you can rattle it about. I understand the benefits of matched spring & struts or coilies, but shocks are ok and i'm doing it on a budget. Is there something that can be changed on the spring cap front or something else like a spacer or something to stop this? The spring caps are the later gti style flat type rather than the early domed types.
