Author Topic: 'ideal' oil temperature  (Read 5372 times)
Offline fufflenarnia
« on: 08 July 2012, 17:16 »
Hi all,
What oil temperature should I bed getting on mfa after a good run? My coolant temperature is a solid 90°c, but the oil temp is coming up at 130°c which seems a little high to me.
I have a mk3 2.0 8v agg, '96.
Thanks,
Steve
Offline itavaltalainen
Re: 'ideal' oil temperature
« Reply #1 on: 08 July 2012, 17:49 »
130 degrees?
Does your AGG have a water/oil heat exchanger? Where is the temp sensor, original MFA?
I have not managed to get my 2E much above 100, and that with pedal down going full speed in a fully loaded car on the german motorway.
« Reply #2 on: 08 July 2012, 17:56 »
Yes, it has the oil/water heat exchanger and all the original components as far as I can tell.
It makes no sense that it could be that much higher than the coolant.
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 08 July 2012, 18:17 »
oil temp sender?
blocked oil cooler?
Mines abf but never had it over 110 degrees .
Offline Ess_Three
« Reply #4 on: 08 July 2012, 18:51 »
oil temp sender?
blocked oil cooler?
I've seen mid to late 120Cs...I'd not worry about it, to be honest.
Just run decent oil.
..but gaining motorcycles.
Offline Khare
  • The bear that khares
« Reply #5 on: 08 July 2012, 20:29 »
Anything over 110 I think is far too high unless you're on a track. Highest I've seen mine is 110 and that was on the road giving it plenty of welly.
« Reply #6 on: 08 July 2012, 20:36 »
Ok, thanks guys, I need to do some investigating.
The engine it actually in a vw camper van - 1986 t3. So is canted over at 50°.
It is not an unusual conversion, but you have to use a sump and oil pickup off a jx diesel engine (from a t3) and it is a great engine for a van, lots of grunt!
I don't have any oil pressure lights on, but am wondering if the oil pressure is low - so I will have to check.
I will also blow through the oil/water cooler to check that is not blocked.
Thanks for the help - let me know if you have any more ideas.
« Reply #7 on: 08 July 2012, 20:41 »
I used to see around 110, 130 is a little high
Offline Khare
« Reply #8 on: 08 July 2012, 21:02 »
Don't think any Golf engine is designed to operate at a 50° tilt.
« Reply #9 on: 08 July 2012, 21:10 »
They will be fine, older Transports had Golf engines in them.
