Author Topic: Contacting JOM  (Read 730 times)
Offline dom
  • Back in a Mk4
Contacting JOM
« on: 07 July 2012, 16:51 »
Car was MOT'd yesterday and just about scraped through, one of the advisories was play in o/s front strut. Spoke to the bloke who tested it and he said that there is a lot of play on the strut between top & bottom.
The coilovers have only been on the car for a few months, so needless to say I'm a bit pissed off. From what I can gather it's a common problem, has anyone on here managed to contact JOM before? If so was it just via the e-mail form on their website?
I also had advisories for split axle bushes, leaking PAS pipe, leaking gearbox flange seal and binding rear brake :rolleyes:
Offline cullygti
Re: Contacting JOM
« Reply #1 on: 07 July 2012, 16:55 »
give damian a shout from dpm performance as he sells a lot of jom stuff and will be able to tell you the crack on what to do there is also a fault with the jom that you need to take them apart and tighten up the insides did you know about this common fault  :smiley:
my joms had this fault before they got fitted and after tighening the insides they been ok  :smiley:
« Last Edit: 07 July 2012, 16:57 by cullygti »
