Author Topic: still issues  (Read 3875 times)
Offline daz veedub
  • Operation 1.8t bolf
still issues
« on: 07 July 2012, 16:31 »
put brand new ignition module on today due to car missfiring and no boost finished work put part on was fine at 1st then it happens again no fault codes  :undecided: ive checked the wiring seems fine
Offline topher
  • Administrator
  • fully functioning
Re: still issues
« Reply #1 on: 07 July 2012, 16:38 »
i've not kept up with your issues so don't know what you've tried yet. is the maf good?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: still issues
« Reply #2 on: 07 July 2012, 17:05 »
Fault codes are a rare thing on the AGU unfortunately mate. Same as Chris, MAF ok?
Offline daz veedub
Re: still issues
« Reply #3 on: 07 July 2012, 21:09 »
just took for quick spin got 2 fault codes now 01262 n75 valve and 16486 maf so sprayed maf with contact cleaner and put another n75 that a got cleared codes gonna go try it now  :lipsrsealed:
Offline Toby
  • Car - less
Re: still issues
« Reply #4 on: 07 July 2012, 21:16 »
Sell it  :lipsrsealed: :laugh:             :embarassed:
Currently down under
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: still issues
« Reply #5 on: 07 July 2012, 21:49 »
and the result...?
Offline Toby
  • Car - less
Re: still issues
« Reply #6 on: 07 July 2012, 21:59 »
Only been 50 mins wazza  :laugh:
Offline daz veedub
Re: still issues
« Reply #7 on: 07 July 2012, 22:00 »
missfiring has gone  :undecided: o.5 boost is the best shes doing  :grin: plugged in again and got the 01262 n75  :sad: dont suppose any off my fellow dubbers has a C n75 valve going cheap  :undecided:
Offline Toby
  • Car - less
Re: still issues
« Reply #8 on: 07 July 2012, 22:01 »
In nothing pal!
Everything plugged in as it should?
100% sure no boost leaks?!
Offline daz veedub
Re: still issues
« Reply #9 on: 07 July 2012, 22:05 »
yep all plugged in no leaks and only that fault code now  :undecided:
