Author Topic: scooby alloys on mk4 ?  (Read 1614 times)
Offline rench
« on: 06 July 2012, 23:55 »
is it possible to run scooby alloys on golf? they have 5x100 but think the center bores are different if so can you get spigot rings to fit them?
Offline Steve_PD
Re: scooby alloys on mk4 ?
« Reply #1 on: 07 July 2012, 00:02 »
No as the centre bore is smaller than the bore on the mk 4. 56.7mm on the scooby and 57.7 on the mk4. you could get a machine shop to turn the centre bore out 1mm though
« Reply #2 on: 07 July 2012, 00:08 »
Also offset is wrong and they tend to have smaller bolt holes.
Offline DunnDeal12
  • Limited
« Reply #3 on: 07 July 2012, 00:57 »
you have to use wobble bolts
Offline mcgee9t2
« Reply #4 on: 07 July 2012, 11:40 »
if the bolt holes are smaller then you wouldnt be able to get the wobble bolts through so would make no difference
Offline Steve_PD
« Reply #5 on: 07 July 2012, 12:32 »
Just get the bolt holes drilled out at the machine shop when they do the centre bore and the offsets are usually high so just space them out to suit.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 07 July 2012, 13:39 »
worth noting if I ever want to look for some wheels then  :wink:
« Reply #7 on: 07 July 2012, 22:39 »
Wobble bolts are to allow a 2mm difference in pcd.
