Author Topic: Noisey front windows  (Read 1787 times)
Offline shaft69
« on: 06 July 2012, 13:17 »
Noticed when drop my front windows more than 4" they rattle like there loose, not stripped them down yet but both windows do it. Easy fix or new parts???
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
Re: Noisey front windows
« Reply #1 on: 06 July 2012, 13:22 »
http://www.golfgtiforum.co.uk/index.php?topic=107692.0
http://www.golfgtiforum.co.uk/index.php?topic=27944.0
Give these two a read, might be a similar problem?
Second link if for the fix  :cool:
« Last Edit: 06 July 2012, 13:27 by Xtrhardcore »
Mk4 Gti - Gone but not forgotten!
Offline GTi_James
« Reply #2 on: 06 July 2012, 13:26 »
will be taking my front doors apart tomorrow as im getting a rattle and need to resolder, could be clips? plastic ones fail, iv got the metal ones to put in
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 06 July 2012, 16:29 »
this will be the clips failing, you will need the repair kit from VW and a few hours of your time  :wink:
Offline GTi_James
« Reply #4 on: 06 July 2012, 17:53 »
+1
Offline shaft69
« Reply #5 on: 06 July 2012, 18:47 »
Thanks lads
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Tezmax
« Reply #6 on: 06 July 2012, 19:00 »
+2  Plastic clip went on my drivers side, opening the window then it disapeared into the door :sad:
There is a fair bit to do and not straight forward as when u take ur interior door skin off there's another one with cables threading through back and forth.
I opted for the full replacement which was cables, guides and clips. It all comes in one piece so it was out with the old and in with the new, cost was around £100.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline GTi_James
« Reply #7 on: 06 July 2012, 19:12 »
i think there a clip in youtube and it was done in about 15 mins, a bit fiddly but doable especially if your mech minded, i think you can buy the clips for about 15£....dont qoute me though
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 06 July 2012, 20:39 »
Once I had everything out it took me about 20 mins to fit the new motor and clips, I reused my mech as there was nothing wrong with it, just the motor had chewed the cables lol
Offline GTi_James
« Reply #9 on: 06 July 2012, 21:29 »
ah, well there we are lol  :laugh:
