Author Topic: Help Please  (Read 4342 times)
Offline JayNesbitt
Help Please
« on: 05 July 2012, 19:00 »
Having bought my pcd adapters to fit Porsche wheels, I have realised now,
I dont have the necessary studs...
The adapter bolts to the hub,m14 bolts (supplied)
However, I don't have the studs to bolt the wheels to the adapter...m12x??
The original supplier of my adapter (R-Tec) can supply them for £30,is this reasonable?
The local haldfrauds was no help at all.
Any help is welcome
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Help Please
« Reply #1 on: 05 July 2012, 19:45 »
However, I don't have the studs Do you mean the BOLTS to bolt the wheel to the adaptor? to bolt the wheels to the adapter...m12x??
Any help is welcome
If so then yes I guess £30 is reasonable for 20 bolts...Just over a quid each  :nerd:
Offline JayNesbitt
Re: Help Please
« Reply #2 on: 05 July 2012, 20:03 »
I was under the impression the adapters required stud instead of bolts?
I'll upload a picture in 5 mins
Offline JayNesbitt
Re: Help Please
« Reply #3 on: 05 July 2012, 20:52 »
Outer holes are clearly m12 but insure if 1.25 or smaller :-/
Re: Help Please
« Reply #4 on: 05 July 2012, 21:20 »
Porsche wheels will need genuine bolts from memory.
Offline JayNesbitt
Re: Help Please
« Reply #5 on: 05 July 2012, 21:28 »
Porsche bolts are m14x1.5 way to big...
Nipped to a local Audi specialists,they had a bolt that gripped 4 threads but no further :-/
Re: Help Please
« Reply #6 on: 05 July 2012, 21:53 »
Well you need to confirm what taper they need to be as a start, I am guessing radius so mabe look at mk3 Golf 4stud bolts.
« Last Edit: 05 July 2012, 22:04 by Wayne »
Offline Thom89
  • Looking for an "Icebreaker"
Re: Help Please
« Reply #7 on: 05 July 2012, 22:18 »
Porsche wheels are normally held on with Alloy nuts, aren't they?
Thom
Offline JayNesbitt
Re: Help Please
« Reply #8 on: 05 July 2012, 22:18 »
Worth a try,luckily a day off work tomorrow so plenty time to look around
Also the option of having studs made locally.
I am determined to get the wheels on!!
Re: Help Please
« Reply #9 on: 06 July 2012, 00:32 »
Just to clear one point up you need to confirm 100% what taper seat the bolts / nuts need to be or you run the risk of the wheels coming loose.
