Author Topic: what gearbox do i have  (Read 2033 times)
Offline jims13
« on: 16 June 2005, 18:46 »
it has 4E stamped on it, and has a linited slip diff in it  :cool:
im a bit confused, i no it should have a 2Y stamp on it.
so any ideas what it is out of.
surely not a early gl , 4+E (type thing) vw is it.
jim
______________________________________
info@jpautomotive.co.uk
07747 004740
vag parts and tuning
Offline mk1
Re: what gearbox do i have
« Reply #1 on: 16 June 2005, 20:25 »
What makes you think it has a lsd fitted?.
Steve.
Offline jims13
« Reply #2 on: 16 June 2005, 23:11 »
did the tried and tested , rev to 5000 dump clutch routine, and see how many lines you leave behind.
thinking the box may be from a maestro .... :cry:
jim
07747 004740
Offline mk1
« Reply #3 on: 17 June 2005, 17:59 »
Nothing wrong with the box being from a maestro, probably had a easy life :wink:.
One way to check if it has a lsd is to jack up one front wheel and with the box in neutral, try to turn the wheel. If it has a lsd it will be very hard to turn, don't mistake the slight drag you will feel as a lsd, it is normal.
Steve
diagnosis-dub
« Reply #4 on: 28 June 2005, 14:24 »
The MK2 GTI 16V box has the 2Y code and thats not what you have, check the code you have on your box, it's on the flat casting at the bottom of the bell housing.
« Last Edit: 28 June 2005, 14:49 by diagnosis-dub »
Offline jims13
« Reply #5 on: 29 June 2005, 20:37 »
hello all, yeah mk1 , did get it uop on the ramps last week and like you said with the car in neutral the wheels wheere hard to turn and they both rotated.
anyways not moaning just wondering what gains im gonna get , would this be a stronger box, thn the normal 2y one. and is it better suited to a larger enginge , as im thinking of going the 2.0 litre route.
cheers jim
jim
07747 004740
Offline mk1
« Reply #6 on: 29 June 2005, 21:26 »
The box will be OK for a 2ltr, use a 16v pressure plate and centre plate that matches the input shaft on your g/box.
Steve.
