Author Topic: Realistic thoughts about AGU stage 2  (Read 38055 times)
Offline jamie1989
Re: Realistic thoughts about AGU stage 2
« Reply #170 on: 26 July 2012, 23:18 »
Im goin down for the day but nothins been promised as they wanted it for a week ideally.
Updates will be next friday  :cool:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline km
« Reply #171 on: 26 July 2012, 23:42 »
a week?!  :undecided:
Offline golfyste
  • Project track car
« Reply #172 on: 27 July 2012, 09:41 »
When you have a turbo swap it tends to take longer Then a day  :cool:
MMMMmmmmm I do want a reliable motor but pushing sounds like fun too  :evil:
I like being risky  :laugh:
Offline jamie1989
« Reply #173 on: 27 July 2012, 11:00 »
But I dont like breaking down either lmao  :evil:
Anything around chris's spec would make me more than happy  :cool:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #174 on: 27 July 2012, 13:29 »
I'm in 2 minds whether to fit this larger bore manifold or just port out my one...
Offline DunnDeal12
  • Limited
« Reply #175 on: 27 July 2012, 13:31 »
port it Y risk the other one cracking?
Offline jamie1989
« Reply #176 on: 27 July 2012, 13:35 »
I would take the standard one off and port it, I wanted to do the same but couldnt be bothered after the hassle fitting the k03s haha
Better pic of THS intercooler.
Offline km
« Reply #177 on: 27 July 2012, 14:17 »
what do you mean? is the turbo fitted already, taking up to r tech. or are r tech fitting it too?
actually, you could answer me. going for same setup as you from ko3. how long did they have your car for? :smiley:
Offline jamie1989
« Reply #178 on: 27 July 2012, 14:29 »
Most people go for stage 1 then 2 which is a 3 hour session job done if the car is healthy etc.
I ideally want a custom map as I want my bigger injectors and bigger maf added, However I cant afford to leave the car for a week because of my job atm. Custom map is week long.
So AGU with k03s and forge actuator and yellow spring
forge 007p yellow spring
3inch turbo back with decat
THS front mount intercooler
5 piece silicone boost kit
Creation sprts tip
Catch can
The above is ideal for stage 2 on AGU but if I add my Calibra injectors and VR6 maf then a custom map would be needed as im pushing more air and fuel through.
Offline golfyste
  • Project track car
« Reply #179 on: 27 July 2012, 15:49 »
Creation sprts tip
Catch can
^ pretty much  :laugh:
Had mine for a week  :cool:
