Author Topic: Which TIP  (Read 966 times)
Offline Dalo Harkin
Which TIP
« on: 04 July 2012, 09:07 »
which TIP do people use when running a K03s and a 3'' MAF?
Offline pickles
  • Next!!!
Re: Which TIP
« Reply #1 on: 04 July 2012, 11:39 »
usually a silicone TIP m8 ie forge, just make sure you get the right 1 for your engine, you may need to block off some holes as i did if your on an AGU
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline DunnDeal12
  • Limited
Re: Which TIP
« Reply #2 on: 04 July 2012, 11:42 »
just use x2 80-70mm reducers for either side of the maf then a 70mm aluminium coupler to connect the tip.
Offline Dalo Harkin
Re: Which TIP
« Reply #3 on: 04 July 2012, 13:20 »
this was my plan, but as I havent bought the silicone TIP was wondering if there was one with a 3'' end, cheers
Offline jamie1989
Re: Which TIP
« Reply #4 on: 04 July 2012, 13:28 »
No unless its custom made you wont get one that 3inch.
Just use joiners I assume thats what others do and its what im goin to do.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline DunnDeal12
  • Limited
Re: Which TIP
« Reply #5 on: 04 July 2012, 15:03 »
or you could buy one of these http://www.creationsmotorsport.com/product-detail.php?pid=421 and get a aluminium part machined to fit the turbo.
