Author Topic: Head gasket? 8v GTI  (Read 3612 times)
Offline ImpactUK
Head gasket? 8v GTI
« on: 03 July 2012, 14:30 »
Hey everyone, I recently got a GTI and noticed that it's drinking coolant like mad. Today I changed my oil breather pipe and noticed a lot of creamy liquid coming out of the head, as well as on the oil cap. I hope to god this isn't head gasket because I can't afford to get it fixed, so tell me some good news?
Here's an image
Gavv8
Re: Head gasket? 8v GTI
« Reply #1 on: 03 July 2012, 14:48 »
Have a good look around the engine bay when hot for staining, make sure the heater is blowing nice and hot and that the engine runs up to temperature ok and sits in the middle of the dial.
If you can't find any leaks and the heater/temperature is not right take it to a garage and get them to put a 4 gas analyser over the coolant expansion tank to see if there are combustion gases in the coolant, also have a look under the oil filler cap for heavy yellow deposits.
Offline trog_nfs
« Reply #2 on: 03 July 2012, 14:56 »
Get the coolant sniff tested!
That will tell you if the HG has gone.
If it hasn't, it is probably the oil cooler where the water is going  :smiley:
Offline ImpactUK
« Reply #3 on: 03 July 2012, 15:04 »
Thanks for the quick reply guys
I found some very old looking staining on the right side of the head near a pipe, but i didn't think much of it. Heaters are blowing very very hot and the engine temperature sits in the middle.
I'll give the expansion tank a sniff soon. What should it smell like if its bad?
I bought the car and it started to overheat on the way home. Checked the coolant and it was basically empty, so i filled it up. This was 3 days ago and its already drank 5ltrs
Where is the oil cooler? How can i test this too?
Thanks again!
Offline trog_nfs
« Reply #4 on: 03 July 2012, 15:13 »
lol, sniff test is a laymans term for the combustion gas test - garages have a container full of a dye that changes colour in the presence of exhaust gases. If it does this when gas from the coolant tank is used, its a sure sign the headgasket has gone.
The oil cooler is on the front of the engine where the oil filter screws into. If you think its this, you can disconnect both the coolant hoses and connect them together to bypass the oil cooler. If no coolant is lost, jobs a goodun'
Sounds like you are losing coolant from the coolant flange on the side of the head. Have a look at the complicated looking one on the front of the engine too. Both are common for the seals going and leaking water when hot.
Offline ImpactUK
« Reply #5 on: 03 July 2012, 15:19 »
HAHAH, now i feel like a moron. I was seriously going to go outside and smell the expansion tank :nerd:
Right, i'm gonna go take a look now.
How likely is it that the HG has gone?
Gavv8
« Reply #6 on: 03 July 2012, 15:19 »
Had this happen on mine.
Gavv8
« Reply #7 on: 03 July 2012, 15:21 »
The 8v is not know for HG problems but if its had a leak and overheated badly then that'll damage the HG.
Offline ImpactUK
« Reply #8 on: 03 July 2012, 15:37 »
Went outside to have another better look and found this on the pipe at the front
Also, just in case, i did smell the expansion tank haha. It smelt a bit like petrol, but i can't be sure.
Offline ImpactUK
« Reply #9 on: 03 July 2012, 16:51 »
Block test confirmed head gasket. Got quoted £450 quid for a repair, is this good?
Wondering whether to attempt it myself or just wack another engine in...
