Author Topic: INTERCOOLER  (Read 9095 times)
Offline markgti1.8t
Re: INTERCOOLER
« Reply #20 on: 04 July 2012, 12:17 »
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline rio_gti
Re: INTERCOOLER
« Reply #21 on: 04 July 2012, 13:02 »
What ever you do get the remap LAST or you won't get the full benefit of it
Offline golfyste
  • Project track car
Re: INTERCOOLER
« Reply #22 on: 04 July 2012, 13:33 »
thanks see then all this is fited to my car do you think it will be near the 300 bhp mark thanks
Check Toby's thread for a idea  :wink:
Offline Chris#101
Re: INTERCOOLER
« Reply #23 on: 04 July 2012, 18:06 »
Didnt realise that you were aiming for 250+
IMO your still well off the spec list for the 300 mark :lipsrsealed:
Your going to be needing
*Badger 3" tip
*Injectors
*3" maf
*K04-023 or a form or hybrid
*Possibly LCR fuel pump & F.P.R
*Relentless high flow manifold
*3" turbo back, decat/sports cat exhaust
*atleast 2.5" intercooler pipework
*A big FMIC (forge. ths size) scrap the ones your looking at.
*W.M.I possibly
*Clutch
*forge actuator
*A good tuner i.e R-tech
Probably a good £1.5k+ above  :lipsrsealed:
and even with the above supporting Mods, you might find you have worn engine parts etc which will then of course limit your power out put :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline toby2can
Re: INTERCOOLER
« Reply #24 on: 11 July 2012, 19:50 »
chris just out of interest wat if any dump valve are u running. cheers
2002 Golf Gti AUM
Offline golfyste
  • Project track car
Re: INTERCOOLER
« Reply #25 on: 11 July 2012, 20:08 »
Best recirc valve is a forge 007p or 008p if You wanna pay more not much difference tho
Offline Scott-R
  • GoT BoosT!
Re: INTERCOOLER
« Reply #26 on: 13 July 2012, 15:30 »
*Badger 3" tip
*Injectors
*3" maf
*W.M.I possibly
*Clutch
*forge actuator
If you can get me that for 1500 ill send you cash the now ha i was £450 for clutch, then like £300 for map then actuator and recirc valve was near £200+ .. £600 for my Ko4... £180 for full exhaust.. and many more your looking at a LOT more for 300bhp tho ... im looking for an intercooler and its looking very expensive ha
Golf GTI ... What else would you have?
Offline Scott-R
  • GoT BoosT!
Re: INTERCOOLER
« Reply #27 on: 13 July 2012, 15:56 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: INTERCOOLER
« Reply #28 on: 13 July 2012, 16:20 »
Offline Scott-R
  • GoT BoosT!
Re: INTERCOOLER
« Reply #29 on: 13 July 2012, 17:12 »
Ordered it after posting that ha so should be here soon.  :nerd:
