Author Topic: anyone used one of these and if so how accurate are they??  (Read 1933 times)
Offline richw911
Be careful as they don't work with some cars  :smiley:
Offline mcgee9t2
as that one has canbus in the title and mk4s dont have can bus i dont think that would work on a mk4
Offline scarr89
  • Mk4 Golf, DERV FTW!
Offline Scott D
Have been using one for a while now and it works on my 2003 MK4, using it with an Android app called OBDscan to monitor MAF G/S and fuel trims. Does have a bit of lag but readings are the same as VCDS and a lot more accurate than Torque.
Handy to have in the car but wouldn't rely on it for logging.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline DunnDeal12
  • Limited
doesn't work on my 99 mk4
Offline golf-sib
  • Турботазик
Works on mk4, but not early ones, only ecu it works with is the me7.5 which is AUM onwards, but it won't work with AGU as that uses the 3.8 ecu.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline wolfie1981
thanks guys
Offline DunnDeal12
  • Limited
god damn crappy agu ecu.
Offline JimBR
Wow you mean an AUM is actually better for something other than the turbo  :huh:
