Author Topic: car: dead  (Read 1533 times)
Offline Tazzy
car: dead
« on: 01 July 2012, 22:17 »
seems ive lost all electrical power
as i dont use the car for 6 days, i was expecting it to be flat, which it was, disconnected the positive terminal, put the charger on, left it for a bit, conected the the pos term again (this usually just does the job) but as i went to turn the key, there was a 'popping' sound from under the bonnet, when i lifted the bonnet there was a burning smell
ive checked every fuse, theyre all fine, to make things worst, ive cross-threaded the terminal bolt
- what was the popping and burning?
- what shall i do?
- what have i broke?
cheers ta, thanks very moochos
If It Comes Off, Modify It!
Offline richw911
Re: car: dead
« Reply #1 on: 01 July 2012, 22:28 »
Check the fuse box on top of the battery......
Offline Tazzy
Re: car: dead
« Reply #2 on: 01 July 2012, 22:47 »
checked, as i have to open that to get to the pos term, i was suggested it could be the flat strips of metal, but they are also in tact
Offline mcgee9t2
Re: car: dead
« Reply #3 on: 01 July 2012, 22:56 »
if youve threaded a bolt then chances are the conection between the battery and the terminal wasnt very good and could have been the current arcing across into the termination.
however from the burning smell ide say your starter motors burnt out?
Offline Tazzy
Re: car: dead
« Reply #4 on: 01 July 2012, 23:10 »
ok, thanks, why would the starter motor die when the car only gets started once a week? :/
Offline leigh_harty
  • Audi AGU
Re: car: dead
« Reply #5 on: 01 July 2012, 23:30 »
I would have thought starting it less is worse for it, gives it chance to sieze up  :undecided:
Dont lose your dinosaur!
Offline richw911
Re: car: dead
« Reply #6 on: 01 July 2012, 23:39 »
Check the thick wires to the starter and alternator, and the earths.
Offline Tazzy
Re: car: dead
« Reply #7 on: 02 July 2012, 07:03 »
hmmm, this is were my knowledge of engines stops, where is the starter motor located and what does it look like?  :embarassed:
Offline golf-sib
  • Турботазик
Re: car: dead
« Reply #8 on: 02 July 2012, 09:32 »
Just underneath the battery tray to the left. I'd check the cables to it first as they are known to get damaged, easiest way to access starter is from underneath the car as its strapped in with long bolts to the engine.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline leigh_harty
  • Audi AGU
Re: car: dead
« Reply #9 on: 02 July 2012, 13:51 »
A deep 18mm socket will make your life a lot easier if I remember
