Author Topic: Coolant leak  (Read 1626 times)
Offline roberts1992_123
Coolant leak
« on: 01 July 2012, 20:48 »
hi, i have a mk4 1.8t and the coolent warning light cam on so i checked it and it was low. i topped it up but i noticed crusty redy pinky stuff around some of the coolent hoses etc..
the temperature gauge stays half all the time.
could it be head gasket ?
could it be the radiator ?
also when i put the heater on it smells real bad like k seal or something has been put in.
oil level has stayed the same. the oil cap hasnt got mayonisy gunky stuff and there doesnt seem to be oil in the coolent.
what could be my problem?
sorry im new to golfs dont really no what im doing lol.
thanks josh
« Last Edit: 01 July 2012, 21:01 by Rhyso »
Offline Dalo Harkin
Re: Coolant leck
« Reply #1 on: 01 July 2012, 20:56 »
Which hoses have the coolant residue on?
check both sides of the block, and where the thermostat housing and sensor are
Offline Anthony
Re: Coolant leck
« Reply #2 on: 01 July 2012, 20:58 »
Do the coolant hoses feel rock hard when you have been for a run ? also try sniffing the resorvoir to see if it smells of fumes
2003 GT Tdi 150
Re: Coolant leck
« Reply #3 on: 01 July 2012, 21:03 »
The top left hose which goes to intercoller has it crusty stuff and a few right side ones.
Re: Coolant leck
« Reply #4 on: 01 July 2012, 21:04 »
the hoses feel normal to me. the resorvoir just smells of some coolent stop leck. not oily or anything.
i havnt lost any power either still pulls well
Offline Dalo Harkin
Re: Coolant leak
« Reply #5 on: 01 July 2012, 21:32 »
Since refilling it have you lost any?
sounds like overheating if its crusty
 :undecided:
where abouts are you?
You could do with checking the water pump is ok, do this by removing the top hose on the expansion tank and holding it over the expansion tank, when you start the car you should have a steady stream
Offline jagger53
Re: Coolant leak
« Reply #6 on: 01 July 2012, 21:33 »
This just happened to me, turns out its the thermostat housing that has a small crack getting it done tommorow.
