Author Topic: Brembo brake fitting, Clearance and Electric gubbins  (Read 1188 times)
Offline Dean_W
Couple of questions for you knowledgeable people.......
Trial fitted the brembo brakes yesterday and I need to fit spacers in order for the wheels to fit.  I think 5mm would do it.
Will I need longer wheel bolts for 5mm spacers?
Best place to get spacers from?
With Anni wheels, can I go wider?
What are people running?
What can I space up to on the rear?
Also, what is the electric gubbins on the caliper?  Is that a brake pad wear indicator?  Does it matter if its not connected?
Sorry for all the questions peeps.  Any help appreciated!!  :smiley:
2002 GT TDI, Hybrid, Diff etc. 221BHP 355LB/FT
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Brembo brake fitting, Clearance and Electric gubbins
« Reply #1 on: 01 July 2012, 18:07 »
Electric connector is the brake pad wear indicator yes...Mine is connected as the plug on the diskpad is bust. Just left with an annoying warning light on your dash and a beep everytime you start the car. I'v learnt to live with it  :grin:
Spacers get on fleabay...I'd imagine 5mm you probably would need some hubcentric ones, just to be safe. Longer bolts as well probs... :undecided:
Offline DunnDeal12
  • Limited
« Reply #2 on: 01 July 2012, 18:24 »
i have bbs ch 18" 8J et35 and i need a 15mm spacer on each front wheel to clear my brembos.
Offline Dean_W
« Reply #3 on: 01 July 2012, 22:17 »
Sweet.  Cheers for the info!
Offline km
« Reply #4 on: 01 July 2012, 22:22 »
if you "think" 5mm is enough, i'd get thicker ones just to be on the safe size. i thought 5mm was enough to clear mine, but ended up with 15mm spacers :lipsrsealed:
Offline Dean_W
« Reply #5 on: 02 July 2012, 17:37 »
Ah.....maybe need to space with washers and then measure with a vernier to ensure it's correct.
Thanks for that!
