Author Topic: Door Trim  (Read 9076 times)
Offline oakgreener
Re: Door Trim
« Reply #10 on: 04 July 2012, 12:45 »
There's no adhesive and the ones in your link are fine. You also need the ones that fit into the door, they sometimes are missing.
These ones. :smiley: :smiley: http://www.ebay.co.uk/itm/VW-MK2-Golf-GTI-Genuine-OEM-Side-Trim-Clips-Grommets-10-Pack-BRAND-NEW-/280870698390?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item416532bd96#ht_3976wt_962
« Last Edit: 04 July 2012, 19:37 by Thom89 »
Offline robw09
Re: Door Trim
« Reply #11 on: 04 July 2012, 14:27 »
Huraaahhh, it is off after some tugging and "gentle" force.  It is those clips from previous post.  I only need three clips and three of the rubber housing that fit in the door holes.
Next Jobs...
Change 1 dipped beam headlight as has a crack in - doddle
Change 1 spot as frosted - doddle
Change the led on the instrument panel for the main beam - not looking forward to!!!
and at some point change front brakes to 16v set-up.
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Door Trim
« Reply #12 on: 04 July 2012, 14:43 »
Cool...
RE LED's read this... http://www.golfgtiforum.co.uk/index.php?topic=143227.0
Yours will be slightly different as the ones in this thread are 2 pin clocks and yours should be 1 pin...
Principle is the same...
For More Info Click To See;
Offline robw09
Re: Door Trim
« Reply #13 on: 04 July 2012, 17:11 »
Good god! That looks tricky.....or am i being a wuss!?
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Door Trim
« Reply #14 on: 04 July 2012, 19:20 »
Wuss!
Couple of screwdrivers and DON'T Force anything!!
Offline Thom89
  • Looking for an "Icebreaker"
Re: Door Trim
« Reply #15 on: 04 July 2012, 20:01 »
Make sure you fit all new clips to the moulding, and all new caps inserted into the door, no matter how good the old ones look!
Tip,  To fit everything properly, wash the rubber caps in warm soapy water, to get rid of release agent used in manufacture, (this will allow the cap to grip the edge of the hole better) let them dry, and push them home into the holes on the door...
Then fit the new white clips to the door moulding, once done, apply a tiny amount of washing up liquid to your finger tips, and very lightly coat the end of the white clips, at the point that they push into the rubber caps... this will stop white clips tearing the caps, or pushing them through to the inside of the door, which is a real pain!
To fix the moulding to the door, simply push it into position, any clips that haven't seated properly, can be sorted with a sharp slap with the palm of your hand...
Thom
Offline robw09
Re: Door Trim
« Reply #16 on: 04 July 2012, 21:41 »
Ok Thom.  Do you know where I get the caps from?  I could only find the clips on VW heritage.
BR
Rob
Offline Thom89
Re: Door Trim
« Reply #17 on: 04 July 2012, 21:57 »
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Door Trim
« Reply #18 on: 04 July 2012, 22:01 »
Our very own Ken has some on Ebay, and as far as I know, the dealers still carry them...
http://www.ebay.co.uk/itm/VW-MK2-Golf-GTI-Genuine-OEM-Side-Trim-Clips-Grommets-10-Pack-BRAND-NEW-/280870698390?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item416532bd96#ht_3935wt_962
Thom
Thanks Thom....
Didn't want to post my own link...
But Yes I do have them in stock and can ship them out tomorrow, so you should have them for the weekend...
Offline robw09
Re: Door Trim
« Reply #19 on: 04 July 2012, 23:01 »
I'll check in with dealer tomorrow and see if they have any in stock, if not I shall order some from Ken.
Thanks
Rob
