Author Topic: Oil light flashing quite annoying  (Read 1731 times)
Offline callummk4reed
« on: 30 June 2012, 15:28 »
Hey guys just changed my clocks and my oil light keeps flashing constantly oil has been topped up so its not that any suggestions on haw to rectify this ie new sensor
more cushion for the pushun
Offline The Mighty Elvi
  • I'm better than you today.
Re: Oil light flashing quite annoying
« Reply #1 on: 30 June 2012, 21:00 »
Oil light is a pressure, not level, warning light.
Use the search, been covered loads of times.
« Reply #2 on: 01 July 2012, 22:55 »
Hey guys looked about and still havnt really found a straight answer can anybody shed a bit of light ? Oh just had and oil service and plugs changed
Offline steve1972
« Reply #3 on: 05 July 2012, 22:16 »
hi ive got the same problem since i changed the clocks on my 91 8v ive also had a flashin oil pressur light
ive changed all the oil pressure switches flushed the oil and changed the oil filter mine drives and performs exactly the same as before the clocks were changed when i plug the old clocks in to test it it dosent flash so im assuming its the clocks
when i find out what it is ill let you know
steve
