Author Topic: Rear wiper motor not working.Mk3 Golf  (Read 6373 times)
Offline Screech16v
  • MK3 20vt AGU
Re: Rear wiper motor not working.Mk3 Golf
« Reply #10 on: 01 July 2012, 12:34 »
Can't you get one of the kids to dangle out the window with a cloth when it gets dirty?
 :grin: what if its a 3 door? sunroof?  :grin: then again what if it doesnt have one?  :huh:
 :laugh:
 Oi mrsaunders i said you could have my 16v badge,still clips on and will stand a morrisons car wash without coming off  :laugh:
Offline mrsaunders
« Reply #11 on: 01 July 2012, 12:37 »
nice i'll pm you
Offline WeekendMechanic
  • Golf MK3 GTD
« Reply #12 on: 14 December 2012, 12:04 »
Having the exact same problem checked the motor manually and it works, fuses and relay working as well.
Rear water pump works and front wipers as well when stalk is pushed backwards,is this correct?
Are both wipers supposed to work at the same time along with the waterpump?
Should I try buying a new stalk?
Anyone else have the same problem and fixed by replacing the stalk?
Offline Screech16v
  • MK3 20vt AGU
« Reply #13 on: 15 December 2012, 15:38 »
Had this on a mk4 today,check the wiring from roof to tailgate ,the bit inside the flexible rubber sleave ,wires had  broken.
Offline Leebob
  • Jetta Sport TDI cr170,Mk3 Colour Concept 8v
« Reply #14 on: 15 December 2012, 19:55 »
Hmm,interesting.Nice one screech,hadn't thought of this.Will check it out asap.
Offline Screech16v
  • MK3 20vt AGU
« Reply #15 on: 15 December 2012, 20:00 »
No probs mate let us know what your findings are  :wink:
Offline Leebob
« Reply #16 on: 16 December 2012, 10:53 »
Checked the wiring this morning and its all good,no damaged wiring to be seen.So this is still a head scratcher for me,unless it is the control stalk thats faulty.
VW BUSH
« Reply #17 on: 16 December 2012, 12:50 »
I changed my stalk, now the MFA don't work :grin:
Still at least the wiper works.....
  • Golf MK3 GTD
« Reply #18 on: 16 December 2012, 12:56 »
I checked the wires in the rubber all good.
VWBush is your problem the same,and what is a MFA?
Offline Leebob
« Reply #19 on: 16 December 2012, 16:45 »
MFA is the button on the end of the stalk that cycles through your mpg,oil temp,weather temp,average speed etc etc.
