Golf mk2
i fully tightent this scrow is there any damage
Topic: i fully tightent this scrow is there any damage (Read 1866 times)
torontovka
29 June 2012, 22:55 »
hi guys..
The car was acting funny,, cold start issue but I fully tightent this scrow and raise the petrol flow,, the car was good at idle,, what will happen if the scrow is fully colsed
check the pic. please
E34 540i 6 Manual
Eibakh Pro Kit | Blistein Shocks | EAT Chip | Racing Dynamics Front Stressbar | Racing Dynamics Swaybar Kit | 850cis Front Brake Kit | Zimmerman Cross-Drilled Brake Rotors All Arround | Hawk Street And Racing Brake Pads |Angel Eyes | 8000k HID Xenon Kit All Arround | Plasma Coils | JB Racing Lightweight Aluminum Flywheel
Vw MK2 Golf 16v
clipperjay
Re: i fully tightent this scrow is there any damage
30 June 2012, 00:04 »
Its the idle screw it meters the amount of air in the throttle body.
If it was running fine before you might have a new air leak somewhere and reducing the idle screw all the way in, kind of compensates for the air leak you might have.
You should start looking for the leak using start spray.
http://www.golfgtiforum.co.uk/index.php?topic=170521.0
http://www.golfgtiforum.co.uk/index.php?topic=55336.msg427955#msg427955
torontovka
30 June 2012, 00:10 »
hhhmmm
thanx for reply, there are 3 pipes from the air filter, 2 of them to the back of the throttle and the last one near the idle scrow,,
do u have a clear diagram for it.
it is mk2 16v.
thanx
E34 540i 6 Manual
Vw MK2 Golf 16v
clipperjay
30 June 2012, 09:52 »
Dont worry about the vac pipes unless they have come off the rubber elbow as long as they are all connected some way they don't need to be hooked into componets they are more to do with really cold countries like Canada they act like cold sensors feed to the metering head or throttle body!
I have no diagrams someone might have pictures to show you where they should be.
torontovka
30 June 2012, 21:39 »
thanx alot brother for your info.
E34 540i 6 Manual
Vw MK2 Golf 16v
clipperjay
01 July 2012, 09:30 »
No prblems mate!
Sometimes the Throttle screw itself gets loose and causes idle problems at that point you change the screw for a new one but check if it struggles to hold idle at cold start, but in Syria that should not be an issue really LOL!
Golf mk2
