Author Topic: new turbo help  (Read 1259 times)
Offline GTIcheeseman
new turbo help
« on: 29 June 2012, 22:07 »
right got a new re conditioned k03s wooo! but i wobbled the intake side and you can feel it all moving inside and it touches the sides now i have felt it when it got sent away knowing it was f**ked and my k03 atm is f**ked and all three feel the same now im slightly confused as i swear turbos run really tight until they wear out can someone help!!
Offline Toby
  • Car - less
Re: new turbo help
« Reply #1 on: 29 June 2012, 22:11 »
Shouldnt be any play. Or tiny slight! In out, not so
Mich side tonside ( blades )
Currently down under
Re: new turbo help
« Reply #2 on: 29 June 2012, 22:13 »
ooh ok then it doesnt go in and out just moves up and down i just thought that they wouldnt do that ??
Offline littco
Re: new turbo help
« Reply #3 on: 29 June 2012, 22:18 »
If its a new rebuilt unit , it will move more than you think it should. Until its had full oil pressure in it then the bearings won't have settled. If its been properly balanced then when it spins it will do it in plane with the shaft, no wobble and won't touch the housings. Don't sweat sure it'll be fine
Offline km
Re: new turbo help
« Reply #4 on: 29 June 2012, 22:21 »
i've got a genuine k04-001 and it has slight side to side play, it's normal :)
Re: new turbo help
« Reply #5 on: 29 June 2012, 22:22 »
ah didnt thinkf that lol just cost a fair amount to fix so i dont want it going bang first time i have seen a new/rebuilt turbo lol
mate a k03 agu will take a straight swap to fit a k03s wont it ?? i have all the gaskets and washers in a kit i bought
Offline km
Re: new turbo help
« Reply #6 on: 29 June 2012, 22:23 »
yeah straight fit, mind me asking where you bought this kit from?
Re: new turbo help
« Reply #7 on: 29 June 2012, 22:24 »
ebay but havent seen any again all the gaskets and washers i have taken off so fair have match and all i gotta take off next is the down pipe
Offline km
Re: new turbo help
« Reply #9 on: 30 June 2012, 01:52 »
fook, that's expensive.
at the moment, i have those 3 gaskets, syringe,
7 bolts and nuts. i assume this is for the downpipe>turbo(4) and turbo>manifold(3).
this is what else i need on the list (I think?)..
056 103 377       (washers x 4)
N 013 812 8       (oil feed pipe washers x 2)
N 013 814 9       (water pipe washers x 4)
N 014 702 13     (oil return bolts x 2)
058 145 791      (washers x 3)
this sound about right?  :undecided:
