Author Topic: Mk3 heater temperature control  (Read 4366 times)
Offline 1 gti
« on: 28 June 2012, 23:49 »
My temperature control is stuck on hot!! Not good when it's 20c, lol. Fan speed and direction still works normal. Taken the unit out and the temperature wheel just turns but cables don't move. What's the possible causes? Cable come off on the flap end? Any help would be appreciated. Cheers
Re: Mk3 heater temperature control
« Reply #1 on: 29 June 2012, 00:10 »
I guess the cable has come off, cannot see it being much else.
Is the engine temp all ok.
Offline 1 gti
« Reply #2 on: 29 June 2012, 09:33 »
Engine temp doesn't go past 70. Doesn't over heat or anything though. That's most prob temperature sensor
« Last Edit: 29 June 2012, 09:37 by 1 gti »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 29 June 2012, 09:36 »
Sounds like you need a thermostat for starters as the temp gauge should sit at 90 once the engine is warmed up.
Offline 1 gti
« Reply #4 on: 29 June 2012, 09:38 »
Thermostat? That's the temperature sensor right?
« Reply #5 on: 29 June 2012, 09:44 »
No, its a temperature sensitive valve that sits beneath a plastic housing on the side of the water pump.
Offline javalin
« Reply #6 on: 29 June 2012, 09:45 »
No seperate bits, temp sensor does what it says, and thermostat regulates the engine water temp to 90c by directing coolant out to the radiator as needed.
If it comes up to 90c when standing, then thermostat needed.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline 1 gti
« Reply #7 on: 29 June 2012, 15:47 »
Doesn't over heat. When driving and ticking over it stays at 70 and no higher. Going to change thermostat and see what happens. I think it's heavy on diesel too
« Reply #8 on: 29 June 2012, 15:50 »
Engines generally overfuel when they don't reach optimum running temperatures as they over compensate with open chokes, cold start valves etc.
Offline 1 gti
« Reply #9 on: 29 June 2012, 16:45 »
Hope the thermostat is at fault then  :smiley:
