Author Topic: Drive Shaft Oil Seal? & Gear Box Oil Level Q. Pic inside  (Read 1741 times)
Offline gerlewis
Hi all,
I was changing the engine oil today and noticed some oil spray around a drive shaft:
Uploaded with ImageShack.us
The rubber gaiter around the driveshaft seems loose, what do I need to replace here? anyone else had this problem?
also will this be gearbox oil I'm losing? If so, I will top up the oil urgently. Or is it just grease?
 - I have located the top-up hole. Is there a way to check the current level?
Offline Steve_PD
Re: Drive Shaft Oil Seal? & Gear Box Oil Level Q. Pic inside
« Reply #1 on: 28 June 2012, 21:59 »
Wont be gearbox oil.
Cant remember if the cv gaitor has a clip at that end or not :undecided:
Offline gerlewis
« Reply #2 on: 28 June 2012, 22:02 »
thanks,
yeah I read here that the driveshafts are sealed:
http://uk-mkivs.net/forums/p/379051/2586115.aspx
(last but one post).
I looked at the other driveshaft, and although there is no visible clip, the gaiter is fixed firm, where as this one slides about!
Any idea how to fasten it? I could just try a jubilee I guess....
Offline cullygti
« Reply #3 on: 28 June 2012, 22:05 »
or just use a zip tie around it and see how it goes
Offline gerlewis
« Reply #4 on: 28 June 2012, 22:06 »
good idea! will give it a go tomorrow.
Offline Steve_PD
« Reply #5 on: 28 June 2012, 22:16 »
Yeah just zip tie it and see how it goes.
