Author Topic: water methanol pump.  (Read 954 times)
Offline DunnDeal12
  • Limited
« on: 28 June 2012, 17:41 »
has anyone got any pics of where they mounted there pump and how you've wired it up as i dont know where's best to put it or what wires to splice into.
and can i wire a switch up to it?
Offline jonrandom
Re: water methanol pump.
« Reply #1 on: 28 June 2012, 21:49 »
I wired mine to the ignition live wire in the plug that goes to the gearbox, so when I turn the ignition on/off so does the WMI.
Mounted my pump in the bumper bar.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 28 June 2012, 22:38 »
under the dash there are switched and perm live terminals you can use for the controller and in the boot I used the 12v socket perm live in the boot. I also added a switch in line if I ever need to turn it off
Offline DunnDeal12
  • Limited
« Reply #3 on: 28 June 2012, 23:03 »
aint got a controller, boost switch only im afraid. ive got the tank in the boot & going mount the pump onto the chassis. its just the wiring i want it to be neat.
Offline shaft69
« Reply #4 on: 28 June 2012, 23:08 »
Got mine in spare wheel well, perm live to red and my black wire goes to controller. Before had controller made own earth point behind carpet and ran perm feed under carpet to under dash.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
