Author Topic: Eibachs or Pi lowering springs.  (Read 1045 times)
Offline StokieShinobi
« on: 28 June 2012, 17:40 »
Hi guys
Just put 17s on my mk4 gti. Now the space in the wheel arches looks even more ridiculous. It HAS to be lowered.
I've always liked eibachs but they only do 30mm ones and I fear it's not enough. I'm more leaning to the Pi 35mm springs. Can anyone give me any advice on these springs and how well they work with 17s
Here are the two I'm looking at
http://www.ebay.co.uk/itm/Volkswagen-Golf-Mk4-2001-2-0-Eibach-Pro-Kit-Lowering-Springs-Kit-E8561-140-/190688925626?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c65f217ba#ht_2040wt_932
http://www.ebay.co.uk/itm/VW-GOLF-Mk4-GTi-98-04-35mm-PI-LOWERING-SPRINGS-/330577389631?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cf7f2a83f#ht_5851wt_922
Any help is much appreciated
Offline DunnDeal12
  • Limited
Re: Eibachs or Pi lowering springs.
« Reply #1 on: 28 June 2012, 17:43 »
for how much you pay for them eibachs you could get a set of cheap coilovers and choose what hight
« Reply #2 on: 28 June 2012, 17:45 »
It is the mrs car. Will cheap coil overs make it super hard? As I will only get moaned at if it is like at lol
« Reply #3 on: 28 June 2012, 17:54 »
So you reckon it's better with these over the eibachs
http://www.ebay.co.uk/itm/VW-Golf-Mk4-4-IIII-98-04-JOM-Coilovers-741001-/290622769469?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AGolf&hash=item43aa77893d#ht_2819wt_922
I thought perhaps top of the range lowering springs are better than poverty spec coilies, I could be wrong though. And ideally I want to lower. Little more that 30, probs around 35 - 40 so they may actually be better
I'm even more confused now lol
Offline damien010685
« Reply #4 on: 28 June 2012, 18:03 »
If you want comfort go with the springs mate Joms are pretty harsh but they are cheap so its up to you but for comfort i would go with eibachs
« Reply #5 on: 28 June 2012, 18:10 »
I think your right
I've just been reading all the posts about joms, like you say, they're good for slam,ing, and good for the price.
I just want to fill the space in the arches but keep comfort. So I guess it's the eibachs
Offline Scott D
« Reply #6 on: 28 June 2012, 23:57 »
Go for the Eibachs, might only be 30mm but still retain a decent ride using them with standard dampers.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
