Author Topic: Accessing oil filter on 1.8t AUM  (Read 1669 times)
Offline AntMk3GTi
« on: 28 June 2012, 15:01 »
Hi
As above really, going to be doing an oil change soon but the engine bay for the 1.8t is a lot more crowded than my old car.
Is it best to change the oil filter from under the car by hand?
Thanks
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Accessing oil filter on 1.8t AUM
« Reply #1 on: 28 June 2012, 15:10 »
It can be done either from the top of the bottom. Just sits down the front of the engine.
Offline AntMk3GTi
« Reply #2 on: 28 June 2012, 15:18 »
Cheers, I can see the filter just doesnt look like i'd be able to grab it to remove it, I cant reach far enough theres too much in the way.
Offline Dalo Harkin
« Reply #3 on: 28 June 2012, 16:16 »
I did mine from underneath, couldn't find my chain thing so hammer and screwdriver time it was to undo it  :grin:
Offline mcgee9t2
« Reply #4 on: 28 June 2012, 18:39 »
ive done mine and a 1.8t, mine from top (non turbo so loads of room) and the 1.8t i did from underneeth cause it was already on axle stands.
however still do able. and try just using your hands before you stick a screwdriver through. alot less messyer and aslong as the filter has had oil rubbed around the seal its normally do able with just your hands.
Offline Gti_Jamo
« Reply #5 on: 28 June 2012, 19:04 »
Big pair of groove joint grips is the tool for the job. Never let me down!!
Offline gerlewis
« Reply #6 on: 28 June 2012, 22:04 »
I did mine from the bottom this evening, pretty easy with a chain tool. Just remove the bottom plastic shroud and get your arms up in there!
(note - place your head off to one side or you get an eye full of crud!  :shocked:)
Offline Tezmax
« Reply #7 on: 29 June 2012, 20:57 »
Hammer and Scewdriver worked fine for me also, 18t aum. from underneath on some halfords cheapo ramps, little taps on the filter rim creating a little grove for the screw driver to grip on then before you know it you will turning it off with ya hand! no butchery  required  :wink:
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
