Author Topic: 1.9 or 2.0???  (Read 8783 times)
Offline seano7015
1.9 or 2.0???
« on: 28 June 2012, 14:54 »
Hi guys im looking to a a mk5 tdi, but im not sure which 1 is better?
The car is going to be used for commuting and short journeys etc!
so which 1 would be better for this a 1.9 or a 2.0?
cheers sean
Offline Agreeable Slick
  • Unit
Re: 1.9 or 2.0???
« Reply #1 on: 28 June 2012, 16:53 »
Tis a toss up this one.
1.9 - Solid engine, on the 150 the camshafts are a weak point but other than that there is not a lot to go wrong. Has a DMF which can go bang, and will cost near to 1k (depending on where you go) to fix it. Limited to either 115, 130 or 150bhp versions. I found the 130 to be best blend.
2.0 - Similar engine, dodgy injectors and DPF filters can play up a lot. Same with the DMF as the 1.9. The upshot is you can either get the 140 version or the 170. They drive a hell of a lot smoother as well. Power delivery is a bit more linear once on turbo as well.
Offline Rhyso
Re: 1.9 or 2.0???
« Reply #2 on: 28 June 2012, 17:57 »
Urm the 1.9 was only available with 105bhp in the mk5's wasnt it?
Those engines you listed Slick were in the mk4  :nerd:
Id go 2.0 140; youll want the extra power if you do long distances.
The 170 is a great engine but if you are doing short journeys then you will more than likely run into DPF problems
  • Unit
Re: 1.9 or 2.0???
« Reply #3 on: 28 June 2012, 21:03 »
I might have skim read the original post. :lipsrsealed: :laugh:
Yes, the 1.9s I've listed at for the mk4. Although I still rate them a little more than the mk5 variants just for robustness.
If it's a Mk5 you must have, I'd get the 140.
