Author Topic: vr 6 engine mods  (Read 1811 times)
Offline gti gaz
vr 6 engine mods
« on: 27 June 2012, 23:06 »
Anyone done a write up on which ones are best ?? Have cone filter cold air feed and a cat back milltec going on this weekend( should sound nice ) don't want to go nuts just keep it simple  :grin:
 Any one in cornwall lets sort more meets!!!!
Offline leigh_harty
  • Audi AGU
Re: vr 6 engine mods
« Reply #1 on: 27 June 2012, 23:36 »
You've covered the simple mods really. Go nuts or home.
Check out search's thread on £200 mods and read from page 7 I think... All mods exceed £200 though :smiley:
Dont lose your dinosaur!
Offline JamesS
« Reply #2 on: 29 June 2012, 09:59 »
With N/A vr6 there are not really any cheap mods that give you much extra power. I have an early dizzy engine and found that re-newing the leads, plugs, dizzy cap & rotor made a big difference with driveability. When I did my conversion I also used a stainless 6 branch manifold and ported and matched the inlet side of things. With the vr6 it's the intake that restricts things so full exhaust system won't give you many extra horsies for the £'s you spend. A Shrick manifold helps but they are £££'s. I think a N/A vr6 can get to 210bhp ish max but that will cost as much as sticking a turbo on there which will easily get you 300bhp+.
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline VR6_Wherry
« Reply #3 on: 29 June 2012, 11:37 »
Yeah, detail it.
Offline Ess_Three
« Reply #4 on: 29 June 2012, 11:56 »
You will be lucky to see a 4-5 BHP gain from a Schrick manifold even with 268 cams fitted...it's all about the huge midrange torque gains with that manifold.
The standard VR6 downpipes/manifolds are good for 225-230 BHP...so you don't need a 6 branch.
A well built 2.9 can easily see 220-230 BHP with the right mods...but, as said above, you can probably turbo it for the cost.
However, you don't get the throttle response and the huge torque of the VR6T just swamps the chassis and doesn't make for as nice a driving car, in my view.
..but gaining motorcycles.
Offline robo22sri
« Reply #5 on: 29 June 2012, 16:44 »
Yup I have heard that stealth are mapping 2.9 engines with schrick, schimmel cams and exhaust to around 220/230
I will hopefully get mine remapped soon enough :)
Offline Ess_Three
« Reply #6 on: 29 June 2012, 17:14 »
From experience, it will take a little more than a 2.9 with schrick, schimmel cams and exhaust to get 220-230 BHP!
It's possible...just not cheap.
You can try adding £1500 for a good head, for a start....or you just won't get the air in/out to make that sort of power.
But, Vince can certainly do a good mapping job!
Offline gti gaz
« Reply #7 on: 29 June 2012, 17:55 »
Cool thanks for the info guys not had much time to have a good look over my new one yet hope to this weekend, paint is good bit of surface rust on tailgate, hole in exhaust but have milltec for that, on 60mm springs but coillies hopfully going on this weekend springs are far to bouncy for me.     Will post some pics in my gti thread soon am thinking manifolds sports cat then maybe porting head that's as far as I have got
