Author Topic: portable air con dont get cold  (Read 2538 times)
Offline Britman
« on: 27 June 2012, 18:33 »
i know a car forum but i guess all air con similar, i tried cleaning my protable air con out of dust from condenser used compressed air and brush and reversed hoover. I knoticed on the top few coils are cold and got ice on but rest are not cold, i guess it koed anyone know much about aircon it a homebase poratble 9000btu, it was used so not sure how much been on i used it  alot as a fan last 2 yrs as well, cheersanyone know anywhere i can ask i guess should buy new one as this was 45 quid used, service and repair be to much.   that dont look to normal to me lol
« Last Edit: 28 June 2012, 21:44 by Britman »
Offline golf-sib
  • Турботазик
Re: portable air con dont get cold
« Reply #1 on: 28 June 2012, 00:15 »
PM Clipperjay, he's quite good with freezing things to near absolute zero. You never know maybe an easy fix.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline clipperjay
« Reply #2 on: 28 June 2012, 20:48 »
Looks like short of gas or dryer could be partialy blocked need to stick gauges to check pressures TBH
When there is not enough gas it boils off quicker and starts to freeze on closest coils i.e not enough liquid refrigerant going through show me better pictures of whole system?
 :nerd:
Offline Britman
« Reply #3 on: 28 June 2012, 21:43 »
hi thanks for reply, i cant work out how to take rest out i.e condensers i not great with things like this what parts did you mean to take pics off. will it be damaged if ran getting frozen, i didnt relise was freezing at first. there was a small cylinder about 2cm thick at top of right side getting frozen too. I used the fan loads since last summer to sleep as white noise maybe it full dust further in grills or inside, its one them homebase ones cheers
« Last Edit: 28 June 2012, 21:46 by Britman »
Offline justalex81
« Reply #4 on: 28 June 2012, 22:37 »
 :nerd:
this. it's lost it's gas.
Offline clipperjay
« Reply #5 on: 28 June 2012, 23:19 »
Okay simple system to me, Its something you can't fix TBF, but best option would be to find a good A/C man to help out they usually charge about £50 call out and insist on a nitrogen leak test there is a reason why its loosing gas usually from valve ports.
The ice is no problem its the leak that important.
Who ever you hire to take the job on make sure they
Nitrogen Oxygen Free (Pressure test)
Use a VAC pump to take air and moisture out.
Change the sausage looking item made from copper its called a Spun drier!
Regass R134a
If the leak is on the (heater matrix (rads) looking parts) it might not be worth fixing!
Anywhere there is copper and valves can be braised/replaced to plug up the leak!
I would charge roughly £150 you might get charged more though dark arts  :rolleyes:
You could just charge it yourself, but it won't last long depends how fast its leaking?
Yeah £45 quid just get a new one this is a domestic jobbie I rarely touch them as I cost too much to help!   :lipsrsealed:
I do freeze the odd animal and sometimes they do come back to life Honest, Cryo is a dark art  :evil:
Offline justalex81
« Reply #6 on: 28 June 2012, 23:22 »
it's a portable air con unit. brand new ones can be had for £150. bin it and get another one!
Offline clipperjay
« Reply #7 on: 28 June 2012, 23:24 »
This  :laugh:
Offline Britman
« Reply #8 on: 28 June 2012, 23:42 »
thanks a lot mate really appreciate the reply, i usually lucky with stuff it never fails, most things arnt worth fixing knowadays due to cost, i seen a few sell for 50-70 and people say hardly been used usually but never really know i guess. are these worth much as scrap? and metals in them? what could i sell it for? may ebay it, cheers i been using it as a fan lol it quite powerfull on high and only uses same as normal fan it takes up a lot of room though for a fan, they weigh like 38kg too :shocked:  :laugh:
« Last Edit: 28 June 2012, 23:48 by Britman »
Offline justalex81
« Reply #9 on: 28 June 2012, 23:49 »
probably worth £20 in scrap.
