Author Topic: Head change now no spark :(  (Read 4265 times)
Offline chrisfletcher
« on: 27 June 2012, 17:53 »
Hello, i just swapped the head from my old golf to my new one and now for some reason she doesnt spark up, ive checked power to the coil pack and it shows 12v and then drops to 8v (ish) when turning over.
Ive also replaced the coil to a working one, leads, dizzy (complete) ignition module :(
Please help, also if theres anyone in the lincoln area willing to pop on over that would be very helpfull.
Chris
Offline molegti
Re: Head change now no spark :(
« Reply #1 on: 27 June 2012, 18:05 »
Did you line the pulleys up when you changed the head? Given its been off id suspect that first. Do the plugs spark out of the engine?
« Reply #2 on: 27 June 2012, 18:22 »
nope nothing out the head, even out of time i would still get a spark
Offline dan_apps
  • too low for british roads!
« Reply #3 on: 27 June 2012, 20:42 »
You say ignition module just changed was it new or second hand? Is it genuine?
Offline Mr Blue
« Reply #4 on: 27 June 2012, 21:06 »
Even if the ignition moduel is broken it can sometimes spark but wont run (digifant 8v)
but what engine is it? I would say the dizzy or you forgot to put the rotor arm back in  :grin:
« Reply #5 on: 27 June 2012, 21:56 »
right managed to get a spark, what does a good spark look like?
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #6 on: 27 June 2012, 22:29 »
A good spark will be bright blue. A poor spark will be yellow. If you have a good spark, it will be ok installed. If you have a pissy little yellow spark, it will probably not spark installed under compression.
Make sure all your pulleys are properly aligned. If the dizzy pully is out its not a biggy, just reposition the distributor.
Oh, and check your earths!! :afro:
Offline oakgreener
« Reply #7 on: 28 June 2012, 09:50 »
8 volts at the coil does't seem enough to me. Is your battery on the way out? The starter motor draws a hell of a high current and if your battery is knackered it wont be up to it.
Try getting a jump start. Good luck
Offline Mr Blue
« Reply #8 on: 30 June 2012, 23:11 »
Just a bump for your the other thread you made.
You sure the timing isnt 180 deg out?
Offline Jimmyrallye
  • 20vt goodness
« Reply #9 on: 30 June 2012, 23:26 »
Could be immobiliser problem :( i had to pull mine out couple of days ago as it armed it self and the golf wouldnt start .. Upon removeing it half of it wos wired in with a speaker wire  :laugh: cwazy sh!t man
