Author Topic: Shocking  (Read 2853 times)
Offline benjam_in
Shocking
« on: 03 October 2003, 10:49 »
My front near side shock has gone, i need a special tool to change the insert don't i? MK2 gti btw
Golf Mk2 Gti 1988
Offline Gambit
Re:Shocking
« Reply #1 on: 03 October 2003, 11:46 »
u'll need to replace both
just buy new complete sealed unit shocks and get rid of the inserts
bout ?10 dearer & a lot less hassle
Offline richandhazel
Re:Shocking
« Reply #2 on: 03 October 2003, 12:14 »
I've always managed to get the cap off without the use of a special tool. Occasionally I've had to carefully angle grind it off but the replacement insert should come with a replacement cap anyway.
Offline modulater
Re:Shocking
« Reply #3 on: 03 October 2003, 12:37 »
All you need is a set of mc'pherson strut peg sockets which are available in halfords and A way of getting the top of the strut off to get at the insert.
I've always used a big pair of stilsons to get the caps off. whilst holding the stut in a vice.
Offline benjam_in
Re:Shocking
« Reply #4 on: 03 October 2003, 13:48 »
i ve got the mac phearson strut tool so the top mounts come off easily, but what is "a big pair of stilsons"??
Golf Mk2 Gti 1988
golfvr6
Re:Shocking
« Reply #5 on: 04 October 2003, 00:04 »
A big pipe wrench. The best way to do it is jack the car up slightly, grip the cap and turn it just to loosen it off, go easy though as the car will be on a jack. After the cap has moved slighty then re-tighten it again. You can buy the special tool but its just as easy to use the pipe wrench.
Offline modulater
Re:Shocking
« Reply #6 on: 05 October 2003, 14:36 »
Sorry I should have said, stilsons are what plumbers and airline fitters use to fit round pipes, they get tighter the more you use force on them, I have found them ideal for getting the top caps of the struts as anything else normally slips off.
When putting the new inserts in the struts use a little antifreeze or fresh oil as it helps to stop them rattling inside and dissipates the heat.
Offline benjam_in
Re:Shocking
« Reply #7 on: 07 October 2003, 12:59 »
Cheers budd think i have a set of those somewhere in me tool box?!? I hate MOTs!
Golf Mk2 Gti 1988
