Author Topic: 5th injector on 2.0 ADY  (Read 1788 times)
Offline ALTERNATOR
« on: 26 June 2012, 20:29 »
Hey guys,
Everyone ever tried adapting a 5th injector to a 2.0 ADY? I got an audi 80 2.3l lying around for spares. I know it has a so called cold start injector so that's a good starting point. I'm thinking adapting the injector to the intake manifold and wiring it to a button inside the car. I guess if I only use it only briefly that the engine pistons won't get that hot :undecided:.
Any other ideas on the subject? Anything else I should be taking into consideration? :undecided:
Re: 5th injector on 2.0 ADY
« Reply #1 on: 26 June 2012, 20:52 »
Daft idea, I cannot see the point even if you got it to work it is going to end in tears
Offline Luke1981
« Reply #2 on: 26 June 2012, 21:00 »
 If you did this your next topic will start something similar to ' Help with my catastrophically overheated ......'  :grin:
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline ALTERNATOR
« Reply #3 on: 26 June 2012, 21:07 »
Hehe :laugh:
Well the thing is I wasn't just going to bolt the injector on there and let it rip :laugh:. I was also thinking about increased air flow. I already have a ported head and was thinking about a custom intake + a "de-humped" throttle body. Although, I see that the idea is pretty dangerous :undecided:.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 06 July 2012, 13:39 »
Disconnect the ECT Sensor, that will overfuel for you insted.  :wink:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
VW BUSH
« Reply #5 on: 07 July 2012, 14:10 »
Hehe :laugh:
Easy tune for the steady of hand :wink:
