Author Topic: Cam chain tensioner gasket, oil leak, help! DONE.  (Read 4041 times)
Offline Big Tone
I have a leak, oil, from the cam chain tensioner gasket. Question is; can I repair this without removing the rocket cover, cams etc?
Or is it a big job? can it be done in-situ? Thought about cracking the three torx bolts on the tensioner but didn't want to do this until I had asked you guys.
Any advice is much appreciated.
« Last Edit: 11 July 2012, 11:31 by Big Tone »
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline golf-sib
  • Турботазик
Re: Cam chain tensioner gasket, oil leak, help!
« Reply #1 on: 26 June 2012, 16:28 »
Is it leaking below the rocker, usually just a rocker off job. No need to touch cams etc. The gasket is a two piece kit, one piece along the outside and a centre piece around where sparks or coil packs sit.
Easy job and done while engine is in, no need to take it out.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Big Tone
« Reply #2 on: 26 June 2012, 16:45 »
Its not the gasket between the rocker cover and the block, its the gasket between the cam chain tensioner and the block, ill try n get a pic.
Offline Mr_Orange
« Reply #3 on: 26 June 2012, 19:34 »
This is a fairly common fault.
There's a special tool to allow you to lift the tensioner up slightly.  I bought the tool already but never got round to buying the seals and fixing it.
Here's a good linkie:
http://www.audizine.com/forum/showthread.php/275895-How-to-1-8T-Cam-Chain-Tensioner-Gasket-replacement
Build thread clicky
Offline Big Tone
« Reply #4 on: 26 June 2012, 21:09 »
Top man, fridays job!
Think iwill be making a tool though, lol.
Offline Big Tone
« Reply #5 on: 08 July 2012, 18:21 »
Done .
Much better  plus no horrible rattle in start .
Result.
Ta
Offline Mr_Orange
« Reply #6 on: 10 July 2012, 20:43 »
Done .
Result.
Ta
Did it cure a startup rattle?  Ours does this from cold, for the first split second (sounds awful).  Didn't know the tensioner gasket fixed this!  I'll be dusting off that tool and getting this done ASAP!
Build thread clicky
Offline Big Tone
« Reply #7 on: 10 July 2012, 22:03 »
Yep. No awful chain rattle anymore.
I used some 6mm stud bar and made up a small bracket. Lol
