Author Topic: EXHAUST MANIFOLD ON A GOLF MK2 DRIVER 1.6  (Read 1772 times)
Offline garboi1234
« on: 15 June 2005, 14:46 »
HEY I NEED HELP. HOW DO YOU PUT THE EXHAUST BRACKETS ( THE C SHAPED ONE) HOW DO DO RE ATTATCH THEM, BECAUSE THEY ARE MADE OF SPRUNG STEEL? ARE THERE SPECIAL ANY SPECIALS TOOLS FOR YOU TO USE TO PPUT THEM ON.
Re: EXHAUST MANIFOLD ON A GOLF MK2 DRIVER 1.6
« Reply #1 on: 16 June 2005, 18:04 »
There is a special tool you can buy, but the way I did it was to use a large Halfords exhaust clamp as a makeshift tool.  What you do is put the clampy bit outside the 2 bolts and loosen them with a spanner untill the clamp opens enough for you to fit it to the exhaust, then loosen the bolts & remove the clamp :)
