Author Topic: Easiest rear beam bushes to fit?  (Read 2313 times)
Offline andc1
« on: 26 June 2012, 11:12 »
If there is such a thing!
Offline jamie1989
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline bobbieboy69er
  • MK4 1.8T AUM
Re: Easiest rear beam bushes to fit?
« Reply #2 on: 26 June 2012, 12:19 »
Its not so much fitting the new ones.... its removing the old ones thatll make you cry  :cry:
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline jamie1989
« Reply #3 on: 26 June 2012, 12:25 »
Ohhh yes, hardest part of the job.
Best drill out the rubber and remove everything first, then youl need either a bloody good chisel I used a elect heavy duty one and smashed it out in the end,
Or use a hacksaw and inverting the blade to cut a slice of the cage then crush it inwards to make it easier to remove from the axle.
The polybush above after we cleaned the axle went it quite easy without any speacial tools just a rubber mallet  :wink:
jockgti
« Reply #4 on: 26 June 2012, 12:35 »
super pro bushes come in 2 bits so would probably be easy to fit
Offline harlemex
« Reply #5 on: 26 June 2012, 13:41 »
poly bushes  :cool:
Offline JimBR
« Reply #6 on: 26 June 2012, 18:05 »
Superpro.
Probably the best quality polybush too.
Offline andc1
« Reply #7 on: 26 June 2012, 20:16 »
Lovely cheers, best place to getbthe super pro ones?
Offline JimBR
« Reply #8 on: 26 June 2012, 20:53 »
Awesome, eBay, Demon Tweeks.
Not really much variation in price really.
Offline Big Tone
« Reply #9 on: 26 June 2012, 21:11 »
The skill is doing it on the drive, with the car on axle stands, without taking the beam off,On your own, with hand tools. Lol :grin:
« Last Edit: 26 June 2012, 21:14 by Big Tone »
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
