Author Topic: Windows with Fob  (Read 1033 times)
RobLebron
Windows with Fob
« on: 26 June 2012, 09:33 »
My windows used to open and close with the key fob, Now they don't........ is there a way to reset/Programme the key fob????
Rob
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
Re: Windows with Fob
« Reply #1 on: 26 June 2012, 11:13 »
I guess you may need to use VAG Com
Mk4 Gti - Gone but not forgotten!
RobLebron
« Reply #2 on: 26 June 2012, 11:21 »
I think il just do without then   :sad:
Must be because the battery died suppose
Offline CM690
  • Golf MK4
« Reply #3 on: 26 June 2012, 11:27 »
I thought you just had to teach the car the limits of the windows again by putting the window all the way down and holding the switch down for 5-10seconds then doing the same for back up and it should work. Give it a try if they worked before your battery died but I'm not 100%. :undecided:
RobLebron
« Reply #4 on: 26 June 2012, 12:27 »
Just tried that didnt work! Its weird because it was fine before battery died (randomly) Thanks for the tip tho  :smiley:
