Author Topic: Ruff idle when warmed up  (Read 2529 times)
Offline Stewy12
« on: 25 June 2012, 20:57 »
As title after driving for awhile gets up to temp then when sat idling revs drop and seems like its missing any ideas
Offline Luke1981
Re: Ruff idle when warmed up
« Reply #1 on: 25 June 2012, 21:01 »
It could be a dirty throttle body or faulty maf sensor. Also check the breather pipes for leaks or blockages. :smiley:
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Stewy12
« Reply #2 on: 25 June 2012, 21:04 »
New breather and spaceship new MAF and pipes magnacor leads new dizzy cap rotor still stuck
Offline stainesy
« Reply #3 on: 26 June 2012, 09:07 »
Coil? If the coil is buggered they usually play up when up to running temp. Iv had 2 coils that played up when engine got warm.
Offline Stewy12
« Reply #4 on: 26 June 2012, 11:42 »
Just found a new coil in the boot so i will give it a try also gonna get a new temp control thing
Offline Len
« Reply #5 on: 26 June 2012, 12:42 »
Have you checked ALL the vacuum hoses?
www.sas.org.uk
www.the-ace.org.uk
Offline Stewy12
« Reply #6 on: 26 June 2012, 13:28 »
Vacum hoses checked no leaks...
Offline stainesy
« Reply #7 on: 26 June 2012, 13:52 »
there was a new coil in the boot? i take it you have just bought the car then? that could be a clue  :wink:
are you sure its not the old coil they stuck in the box when they changed it and the new one is on the car if so.
Offline Stewy12
« Reply #8 on: 26 June 2012, 15:34 »
Had it since Jan but only just MOTed and road worthy (Bought it got given it as its was in a garage for 2 years they could get it started new ecu and away she went)
NA its defo new took old one of covered in sh!t new one is really clean never fitted...Changed coolant sensor as well see how that does hopefully should sort it if not back to square one...
« Last Edit: 26 June 2012, 15:37 by Stewy12 »
Offline Stewy12
« Reply #9 on: 26 June 2012, 18:31 »
Seems alot better after changing coil and sensor
