Author Topic: where do mk3's rust the most?  (Read 5849 times)
Offline robo22sri
« on: 24 June 2012, 22:26 »
As title, mine has a little in the door shut and front wings
but i noticed inside behind the passenger rear light is rusty! :(
the seam sealer has split and is rusty on the outside around the light also  :rolleyes:
bloody hate rust!
Offline GolfGL
Re: where do mk3's rust the most?
« Reply #1 on: 24 June 2012, 22:33 »
For there age mk3's seem quite bad with wings, sills, lower 3/4 and door sections, tailgate below window and probably a few other places
Adam
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline search
« Reply #2 on: 24 June 2012, 22:58 »
yeah lower wings on mine. and some under the door.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline CJA321
« Reply #3 on: 24 June 2012, 23:05 »
Everywere.  :tongue:
Offline kahunajb
« Reply #4 on: 24 June 2012, 23:33 »
Mk1 Leon Cupra TDI - Keeping
Mk5 Golf GTI - Revo Stage 1 - FOR SALE £5,250
Mk3 GTI 16v Anniversary - OEM+ - Gone :(
Mk4 GTI 2.0 - Slow - Good Riddance
Offline twotwofour
« Reply #5 on: 25 June 2012, 12:07 »
Mine has rusty front wings and that's it. The stickies suggest its dependant on year of manufacture to how bad it will rust
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #6 on: 25 June 2012, 12:43 »
All the above really, pay particular attention to the inner sills especially if it has evidence of been jacked up on the edges and has GTI sill covers which trap moisture inside.
« Reply #7 on: 25 June 2012, 13:52 »
Frome what I have read early ones were a lot better, later cars do seem to suffer more rust
VW BUSH
« Reply #8 on: 25 June 2012, 20:40 »
Where the door rubber joins at the bottom at the top edge of the sill- need to pull rubber up to have a proper look
Jacking points, fronts are worse as the jack does not sit on the plastic trim very well and slips off.
If the front points are bent you have rust, on the inside and outside of the of the tubular section.
Rubber floor bungs, rot out every where. not so bad in the pan area as they can be patched easily, the ones on the inner sill are a little more tricky and tend to rot the whole sill out from the inside due to water ingress
Around the windscreen, nice square leading edge around the top of the screen, just what you don't want to avoid paint chips, also a pain to get done as the screen needs to come out.
Under the roof strips, from racks and damaged clip lugs.
Inner wings, ABS grommet. Dont let your inner wing rot out!
Behind rear light cluster, three nuts to check.
Boot lid grommets, where they join the roof area tends to rot behind the rubber.
Roof Ariel, can be fixed, always comes back
These are the hidden spots I always look in as they are structural and are £££ and ball aches.
Wings and doors are never a problem to sort out.
Everything else is a case of looking for the obvious, I find Mk3's are either really rotten or really Clean with trimless models fairing very well on the sills.
You can list a million places to look, but if its obviously rusty when you buy it, you most likely have a rot box anyway :grin:
Offline search
« Reply #9 on: 25 June 2012, 20:51 »
Thinking about it my boot was getting soaked because the boot lid up by the struts have rusted tiny hole so i had to seal it up.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
