Author Topic: Little question  (Read 2195 times)
Offline bobbieboy69er
  • MK4 1.8T AUM
Re: Little question
« Reply #10 on: 26 June 2012, 17:27 »
Ok u all now the Robles I've had especially topher. Well I've only been hitting 14psi. Well today I've been hitting and holding 19/20. I found out y. The pipe that comes off the side of n75 to the metal pipe off top of turbo had split straight off. Web I re connected it I was bak to 13/14 psi. Is the n75 has it
So you were only getting 14psi, then all of a sudden you were getting 19/20, then you found a split pipe, fixed it, now its gone back down to 14 pst again?  thats a bit confusing mate.  Try rewording, dont really make sense?
Have you checked for any other leaks?  do you have access to VAGCOM?
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline golf-sib
  • Турботазик
Re: Little question
« Reply #11 on: 26 June 2012, 19:28 »
His scanned it no codes, the engine is an AGU and I think he had 19/20, then it dropped to 14/15, he found the pipe and replaced it but boost is not back to 19/20, its still at 14/15.
I'd guess there's still a leak somewhere, but maybe not big enough for a fault to throw up... or another idea which seems more feasible as its stage 2 is weak actuator on the turbo could be the culprit!
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline inggti
Re: Little question
« Reply #12 on: 26 June 2012, 22:10 »
Before pipe problem id only hit 14. But wen pipe snapped off I was hitting 19/20 and holding. But it would jolt as if it over boosting. And I used Mitty vac to test actuator and it doesn't lose any pressure
