Author Topic: Little question  (Read 2198 times)
Offline inggti
Little question
« on: 24 June 2012, 21:12 »
Ok u all now the Robles I've had especially topher. Well I've only been hitting 14psi. Well today I've been hitting and holding 19/20. I found out y. The pipe that comes off the side of n75 to the metal pipe off top of turbo had split straight off. Web I re connected it I was bak to 13/14 psi. Is the n75 has it
Offline inggti
Re: Little question
« Reply #1 on: 25 June 2012, 12:54 »
Anybody
Offline DunnDeal12
  • Limited
Re: Little question
« Reply #2 on: 25 June 2012, 13:50 »
sorry mate i cant understand anything you've said.
Offline golf-sib
  • Турботазик
Re: Little question
« Reply #3 on: 25 June 2012, 14:33 »
If I read it right, he is saying that he was hitting 19-20psi, now his turbo is hitting 14psi. He had a look around and found a split pipe that goes from TIP to n75. He has replaced it but it is still only peaking 14psi. Could this be a n75 at fault or something else?
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline jamie1989
Re: Little question
« Reply #4 on: 25 June 2012, 14:36 »
My AGU on stage 1 map with R-tech peaks 14 psi 1st and 2nd gear with no load on engine Ie on flat roads.
But then peaks 16-18psi under load (Steep hill)
The rest of the gears peak 20psi then drop off between 16-18psi.
If that helps  :grin:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline cullygti
Re: Little question
« Reply #5 on: 25 June 2012, 15:50 »
14-16psi and holding is about right for a stage 1 map
Offline inggti
Re: Little question
« Reply #6 on: 25 June 2012, 21:10 »
That's good by its stage 2
Offline inggti
Re: Little question
« Reply #7 on: 26 June 2012, 16:21 »
Bump
Offline golf-sib
  • Турботазик
Re: Little question
« Reply #8 on: 26 June 2012, 16:24 »
What engine and you scanned for faults?
1.8T AGU..
R135
  24
Offline inggti
Re: Little question
« Reply #9 on: 26 June 2012, 16:49 »
Agu. And no fault codes
