Author Topic: Engine Management Light after service  (Read 1063 times)
Offline doom
« on: 24 June 2012, 11:57 »
Hey!
On friday my car went in for an MOT and major service, I also had a specific problem for them to look at: my engine often cut out when slowing down for junctions after pressing in the clutch. It was also pulsating occasionally when idle (no warning lights were on). They managed to sort the problem out by fitting a pre-cat oxygen sensor, but said this kicked up another problem, and now my engine management light has come on?
Is this a common problem? I don't expect to pay for a full service and get my car back with a warning light on, especially when none were on when it went in. :cry:
Just wondering if this has happened to anyone else, and what my options are?
Thanks!
Offline dan2252
Re: Engine Management Light after service
« Reply #1 on: 24 June 2012, 12:06 »
well if hes said theres a new problem what is it? also could be any mk4 for all we know pal what year is it? engine? engine code may seem picky but common faults for a 1.4 to a 1.8t are difffrent, you need it fault scanning. on a computer easyest way first off. if its a 1.8t it could be anything from a dirty throttle body, to knacked breather pipes,
MK4 golf 1.8 turbo agu :)
Offline richw911
« Reply #2 on: 24 June 2012, 12:06 »
Welcome  :cool:
You need to get it scanned first to see whats going on.  :smiley:
See here http://www.golfgtiforum.co.uk/index.php?topic=189447.0
Offline doom
« Reply #3 on: 24 June 2012, 12:08 »
Thanks! sorry it's a 2003 1.4, the guy didn't check out the problem, just said it would need futher investigation.
« Last Edit: 24 June 2012, 12:10 by doom »
Offline dan2252
« Reply #4 on: 24 June 2012, 12:13 »
could be anything mate then. has the garage cleared faults? just thinking if theyve changed sensor and then left ignition on while changing it that would bring a light on
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 24 June 2012, 17:24 »
:afro:
