Author Topic: k04 turbo gains  (Read 1316 times)
Offline markgti1.8t
k04 turbo gains
« on: 23 June 2012, 23:46 »
hi can some one tell me the gains of the k04 turbo with just relapsing it with the k03 no map thanks
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline Toby
  • Car - less
Re: k04 turbo gains
« Reply #1 on: 24 June 2012, 05:36 »
No map?
Y would u do that
Currently down under
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Re: k04 turbo gains
« Reply #2 on: 24 June 2012, 10:22 »
Yeah why?
That's like getting Jessica Alba to your house naked, and just 'looking'.
Offline Chris.
Re: k04 turbo gains
« Reply #3 on: 24 June 2012, 11:13 »
LOL.
Over a k03 you would see a big difference, but you would also see a big difference in price.
A well tuned k03s which comes in hard and holds very good midrange power would easily keep up with a mapped k04.  k04 would also need a lot more bolt on bits than a k03s.
Click For Build Thread
Offline mar_k
Re: k04 turbo gains
« Reply #4 on: 24 June 2012, 15:18 »
you wouldn't be able to just swap the turbo,
How would the engine know it has to supply more fuel without a map?
Besides that Im sure things like the injectors would be way out their range plus other things.
The car would drive like poo by just wacking a k04 on, Plus Im sure if it did run it would shortly die as it would be running lean
Offline markgti1.8t
Re: k04 turbo gains
« Reply #5 on: 24 June 2012, 18:27 »
it will be get map just wondering the differents between the to turbos i have new
Genuine Bosch 42lb Green Giant Fuel Injectors fuel pump turbo back exhaust FRONT MOUNT INTERCOOLER next is the inlet pipe where can i get one from thanks
Offline markgti1.8t
Re: k04 turbo gains
« Reply #6 on: 24 June 2012, 18:31 »
LOL.
what bolt on bit do you mean
Offline Chris.
Re: k04 turbo gains
« Reply #7 on: 24 June 2012, 22:37 »
Intake, intercooling, water meth, downpipe, exhaust, sensors runnnig top notch, plenty cold air into turbo, Good map.
Plenty information out there with the search.
Offline Toby
  • Car - less
Re: k04 turbo gains
« Reply #8 on: 25 June 2012, 07:16 »
Ur neeed deep pockets.
Mine owes me just over 2k on everything including mapping! And its still not finished
