Author Topic: WMI controller is in, YES!!!  (Read 4313 times)
Offline Chris.
Re: WMI controller is in, YES!!!
« Reply #10 on: 24 June 2012, 15:10 »
Not changing any fuelling?
Click For Build Thread
Offline shaft69
« Reply #11 on: 24 June 2012, 15:32 »
Not changing anything now till get both nozzles fitted and on rollers can log everything then. The lad with rollers sell water/meth kits does AEM pretty good stuff ain't cheap. Fueling if req can be altered with unisettings but couple people who I've spoke to haven't needed to but all is in hand.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Chris.
« Reply #12 on: 24 June 2012, 15:41 »
How much was your AEM kit mate?
Offline shaft69
« Reply #13 on: 24 June 2012, 16:15 »
£320 go on the site efi-parts.co.uk
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline shaft69
« Reply #14 on: 24 June 2012, 16:47 »
Personally i'd get this one if was getting one again, bought mine cheap of my mate just had to by progressive controller, solenoid and nozzles.
http://www.snowperformance.net/stage-2-gm-maf-boost-cooler.html
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline shaft69
« Reply #15 on: 27 June 2012, 00:13 »
Doing some more logging today on m62 filled up yesterday with tesco99 deffo a difference, was pulling around 6degrees timing with 95ron fuel 3.5ish with 99ron. added 1.5 so now added 4.5degrees timing pulling still under 6, feels awesome. on motorway intake air temp low as low as 15degrees. Wish my TB spacer would hurry up and come then off on the rollers more logging and few power runs.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline DunnDeal12
  • Limited
« Reply #16 on: 27 June 2012, 08:49 »
did order the usally sideways rally team one? if you have the devils own nozzles they dont fit.
Offline shaft69
« Reply #17 on: 27 June 2012, 11:21 »
Ye the USRT spacer not come yet but got devil and snow performance nozzles. Can always drill and tap if I get stuck, got correct tap for devil nozzles here at work.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline DunnDeal12
  • Limited
« Reply #18 on: 27 June 2012, 13:42 »
yeah they use the same 1/8 tap but the devils own nozzles don't have a lot of thread on and don't go all the way through USRT spacer, so this causes the nozzle to drip instead of a fine mist and you can't counter sink the hole as there's not enough meat on the spacer.
